Octane crash with last Nvidia Driver 418.81
wireframex
Here is the log :
00:00:00 (0000.00) | Log started Mon Feb 4 22:48:23 2019
00:00:00 (0000.00) | Octane Render for Lightwave by Juanjo González. Build 4.02.0.0 (Build date: Jan 24 2019 11:45:01)
00:00:00 (0000.08) | Compiled for LightWave 2019.0 (build 3114)
00:00:00 (0000.08) | Compiled using the Octane API 4.02
00:00:00 (0000.08) | Running on LightWave 2019.0 (build: 3115)
00:00:00 (0000.08) | Running on Octane DLL 4020000
00:00:00 (0000.08) | System: AuthenticAMD unknown, 3783 Mhz., 32 cores
00:00:00 (0000.08) | OS: Windows 8 64-bit
00:00:00 (0000.08) | IPR: init snapshoths system
00:00:00 (0000.08) | IPR: init IPR preview window
00:00:00 (0000.28) | IPR: init a buffer snapshot
00:00:00 (0000.28) | IPR: buffer snapshot ok
00:00:00 (0000.29) | IPR: Init render thread
00:00:00 (0000.29) | IPR: reloading scene - render thread waiting for events before init rendering
00:00:00 (0000.40) | IPR: loading scene
00:00:00 (0000.40) | IPR: Disable IPR events processing
00:00:00 (0000.40) | IPR: Waiting for the full scene updating ...
00:00:00 (0000.45) | IPR: ... Full scene updated.
00:00:00 (0000.45) | Init scene
00:00:00 (0000.45) | Init the root geometryGroup
00:00:00 (0000.45) | Processing the motion blur data
00:00:00 (0000.45) | Get the scene motion blur settings
00:00:00 (0000.45) | Motion blur disabled, computing only one time sample
00:00:00 (0000.45) | Processing time sample 1 of 1, time: 0.000000
00:00:00 (0000.45) | Get camera motion blur data
00:00:00 (0000.45) | * position: 1.290511 0.116049 0.563409
00:00:00 (0000.45) | * target: -86.921245 -5.988808 -46.142242
00:00:00 (0000.45) | * fov: 58.109208
00:00:00 (0000.45) | Get Objects motion blur data
00:00:00 (0000.45) | Object table transformation matrix:
00:00:00 (0000.45) | 1.767078 0.000000 -0.000000 0.000000
00:00:00 (0000.45) | 0.000000 1.000000 0.000000 0.000000
00:00:00 (0000.45) | -0.000000 -0.000000 1.384268 -0.000000
00:00:00 (0000.45) | Object dragon gradients transformation matrix:
00:00:00 (0000.45) | -0.999701 0.000000 0.024433 0.085797
00:00:00 (0000.45) | -0.024433 0.000000 -0.999701 -0.510141
00:00:00 (0000.45) | Object dragon gradients2 transformation matrix:
00:00:00 (0000.45) | -0.992757 0.000000 -0.120137 -0.677996
00:00:00 (0000.45) | 0.120137 -0.000000 -0.992757 0.105038
00:00:00 (0000.45) | Get vertex deformations motion blur data
00:00:00 (0000.45) | Get Lights motion blur data
00:00:00 (0000.45) | Light Light transformation matrix:
00:00:00 (0000.45) | -0.169981 -0.165459 0.128958 1.296905
00:00:00 (0000.45) | 0.000000 0.165978 0.212958 2.000000
00:00:00 (0000.45) | -0.209778 0.134069 -0.104493 -1.491489
00:00:00 (0000.45) | Motion blur data ready
00:00:00 (0000.45) | Processing objects list from LW scene. FIRST PASS
00:00:00 (0000.45) | Number of LW objects: 3
00:00:00 (0000.45) | -> Reading scene UV Maps list
00:00:00 (0000.45) | --> Detected 0 UVMaps in scene
00:00:00 (0000.45) | Processing object: 10000001, name: table
00:00:00 (0000.45) | Object table is a LW object without clones, we must add the mesh to Octane database
00:00:00 (0000.45) | Searching if FiberFX is available in this object
00:00:00 (0000.45) | >>> Processing the number of valid polygons
00:00:00 (0000.45) | >>> This object has 6 of 6 valid polygons
00:00:00 (0000.45) | >>> Adding a new mesh to Octane
00:00:00 (0000.45) | >>> Mesh points: 8, valid polygons: 6
00:00:00 (0000.45) | ----> Searching UV maps in this object
00:00:00 (0000.45) | ----> No UV maps found in this object
00:00:00 (0000.45) | [profile] Function "LWOctane_getVMap" over "" execution time: 0.000 seconds
00:00:00 (0000.45) | >>> Processing vertex per poly array
00:00:00 (0000.45) | [profile] Function "LWOctane_getVertsPerPoly" over "" execution time: 0.000 seconds
00:00:00 (0000.45) | >>> Processing vertex list
00:00:00 (0000.45) | [profile] Function "LWOctane_addVertex" over "" execution time: 0.000 seconds
00:00:00 (0000.45) | +++ Searching object materials
00:00:00 (0000.45) | +++ Found 1 materials inside table
00:00:00 (0000.45) | +++ Material 0 ID: Default
00:00:00 (0000.45) | +++ Searching in the object materials for UVMAP nodes
00:00:00 (0000.45) | >>> Searching UVMAP node inside surface Default
00:00:00 (0000.45) | >>> This material doesn't have a valid UVMAP node
00:00:00 (0000.45) | >>> Processing polygon data
00:00:00 (0000.45) | [profile] Function "LWOctane_addPolData" over "" execution time: 0.000 seconds
00:00:00 (0000.45) | >>> Mesh added, evaluating it
00:00:00 (0000.45) | [profile] Function "LWOctane_addMesh" over "" execution time: 0.000 seconds
00:00:00 (0000.45) | +++ Processing object materials
00:00:00 (0000.45) | > Filtering 1 materials in 6 polygons
00:00:00 (0000.45) | > Filtering 1 materials in 0 hairs
00:00:00 (0000.45) | Used materials in this object: 1
00:00:00 (0000.45) | +++ Processing material Default
00:00:00 (0000.45) | +++ This material has a valid Octane nodal shading tree, processing it ...
00:00:00 (0000.45) | --> Procesing a new GlossyMaterial node
00:00:00 (0000.45) | +++ End of materials processing
00:00:00 (0000.45) | Searching FiberFX hair materials
00:00:00 (0000.45) | +++ Processing object layer maps functions
00:00:00 (0000.45) | --> Get object global dissolve value: 0.000000, state 0
00:00:00 (0000.45) | [profile] Function "LWOctane_addGeom" over "table" execution time: 0.001 seconds
00:00:00 (0000.45) | Processing object: 10000000, name: dragon gradients
00:00:00 (0000.45) | Object dragon gradients is a LW object without clones, we must add the mesh to Octane database
00:00:00 (0000.45) | >>> This object has 87130 of 87130 valid polygons
00:00:00 (0000.45) | >>> Mesh points: 43512, valid polygons: 87130
00:00:00 (0000.46) | ----> No UV maps found in this object
00:00:00 (0000.46) | [profile] Function "LWOctane_getVMap" over "" execution time: 0.001 seconds
00:00:00 (0000.46) | >>> Processing vertex per poly array
00:00:00 (0000.46) | [profile] Function "LWOctane_getVertsPerPoly" over "" execution time: 0.006 seconds
00:00:00 (0000.46) | >>> Processing vertex list
00:00:00 (0000.46) | [profile] Function "LWOctane_addVertex" over "" execution time: 0.003 seconds
00:00:00 (0000.47) | +++ Searching object materials
00:00:00 (0000.47) | +++ Found 1 materials inside dragon gradients
00:00:00 (0000.47) | +++ Material 0 ID: Default
00:00:00 (0000.47) | +++ Searching in the object materials for UVMAP nodes
00:00:00 (0000.47) | >>> Searching UVMAP node inside surface Default
00:00:00 (0000.47) | >>> This material doesn't have a valid UVMAP node
00:00:00 (0000.47) | >>> Processing polygon data
00:00:00 (0000.55) | [profile] Function "LWOctane_addPolData" over "" execution time: 0.082 seconds
00:00:00 (0000.55) | >>> Mesh added, evaluating it
00:00:00 (0000.55) | [profile] Function "LWOctane_addMesh" over "" execution time: 0.096 seconds
00:00:00 (0000.55) | +++ Processing object materials
00:00:00 (0000.55) | > Filtering 1 materials in 87130 polygons
00:00:00 (0000.55) | > Filtering 1 materials in 0 hairs
00:00:00 (0000.55) | Used materials in this object: 1
00:00:00 (0000.55) | +++ Processing material Default
00:00:00 (0000.55) | +++ This material has a valid Octane nodal shading tree, processing it ...
00:00:00 (0000.55) | --> Procesing a new DiffuseMaterial node
00:00:00 (0000.55) | --> Procesing a new Gradient node
00:00:00 (0000.55) | --> Procesing a new WaveTexture node
00:00:00 (0000.55) | --> Procesing a new RGBSpectrumTexture node
00:00:00 (0000.55) | --> Procesing a new ImageTexture node
00:00:00 (0000.55) | --> Filename: E:\01_Lightwave\Octane_content\dragon\Images\noIcon.tga
00:00:00 (0000.55) | --> Procesing a new Projection node
00:00:00 (0000.55) | +++ End of materials processing
00:00:00 (0000.55) | Searching FiberFX hair materials
00:00:00 (0000.55) | +++ Processing object layer maps functions
00:00:00 (0000.55) | --> Get object global dissolve value: 0.000000, state 0
00:00:00 (0000.55) | [profile] Function "LWOctane_addGeom" over "dragon gradients" execution time: 0.104 seconds
00:00:00 (0000.55) | Processing object: 10000002, name: dragon gradients2
00:00:00 (0000.55) | Object dragon gradients2 is a LW object without clones, we must add the mesh to Octane database
00:00:00 (0000.55) | Searching if FiberFX is available in this object
00:00:00 (0000.55) | >>> Processing the number of valid polygons
00:00:00 (0000.56) | >>> This object has 87130 of 87130 valid polygons
00:00:00 (0000.56) | >>> Adding a new mesh to Octane
00:00:00 (0000.56) | >>> Mesh points: 43512, valid polygons: 87130
00:00:00 (0000.56) | ----> Searching UV maps in this object
00:00:00 (0000.56) | ----> No UV maps found in this object
00:00:00 (0000.56) | [profile] Function "LWOctane_getVMap" over "" execution time: 0.000 seconds
00:00:00 (0000.56) | >>> Processing vertex per poly array
00:00:00 (0000.56) | [profile] Function "LWOctane_getVertsPerPoly" over "" execution time: 0.006 seconds
00:00:00 (0000.56) | >>> Processing vertex list
00:00:00 (0000.57) | [profile] Function "LWOctane_addVertex" over "" execution time: 0.002 seconds
00:00:00 (0000.57) | +++ Searching object materials
00:00:00 (0000.57) | +++ Found 1 materials inside dragon gradients2
00:00:00 (0000.57) | +++ Material 0 ID: Default
00:00:00 (0000.57) | +++ Searching in the object materials for UVMAP nodes
00:00:00 (0000.57) | >>> Searching UVMAP node inside surface Default
00:00:00 (0000.57) | >>> This material doesn't have a valid UVMAP node
00:00:00 (0000.57) | >>> Processing polygon data
00:00:00 (0000.65) | [profile] Function "LWOctane_addPolData" over "" execution time: 0.079 seconds
00:00:00 (0000.65) | >>> Mesh added, evaluating it
00:00:00 (0000.65) | [profile] Function "LWOctane_addMesh" over "" execution time: 0.091 seconds
00:00:00 (0000.65) | +++ Processing object materials
00:00:00 (0000.65) | > Filtering 1 materials in 87130 polygons
00:00:00 (0000.65) | > Filtering 1 materials in 0 hairs
00:00:00 (0000.65) | Used materials in this object: 1
00:00:00 (0000.65) | +++ Processing material Default
00:00:00 (0000.65) | +++ This material has a valid Octane nodal shading tree, processing it ...
00:00:00 (0000.65) | --> Procesing a new DiffuseMaterial node
00:00:00 (0000.65) | --> Procesing a new Gradient node
00:00:00 (0000.65) | --> Procesing a new MarbleTexture node
00:00:00 (0000.65) | --> Procesing a new ImageTexture node
00:00:00 (0000.65) | --> Filename: E:\01_Lightwave\Octane_content\dragon\Images\noIcon.tga
00:00:00 (0000.65) | --> Procesing a new Projection node
00:00:00 (0000.65) | --> Procesing a new GaussianSpectrumTexture node
00:00:00 (0000.65) | +++ End of materials processing
00:00:00 (0000.65) | Searching FiberFX hair materials
00:00:00 (0000.65) | +++ Processing object layer maps functions
00:00:00 (0000.65) | --> Get object global dissolve value: 0.000000, state 0
00:00:00 (0000.65) | [profile] Function "LWOctane_addGeom" over "dragon gradients2" execution time: 0.098 seconds
00:00:00 (0000.65) | Processing objects list from LW scene. SECOND PASS
00:00:00 (0000.65) | Second pass check for object 10000001
00:00:00 (0000.65) | Object table has the native Lightwave instancer plugin with 0 instances
00:00:00 (0000.65) | Processing instances ...
00:00:00 (0000.65) | Second pass check for object 10000001 ok.
00:00:00 (0000.65) | Second pass check for object 10000000
00:00:00 (0000.65) | Object dragon gradients has the native Lightwave instancer plugin with 0 instances
00:00:00 (0000.65) | Second pass check for object 10000000 ok.
00:00:00 (0000.65) | Second pass check for object 10000002
00:00:00 (0000.65) | Object dragon gradients2 has the native Lightwave instancer plugin with 0 instances
00:00:00 (0000.65) | Second pass check for object 10000002 ok.
00:00:00 (0000.65) | Setting the objects geometry group to the scene root geometry group, index 0
00:00:00 (0000.65) | Setting the instances geometry group to the scene root geometry group, index 2
00:00:00 (0000.65) | -> Releasing scene UV Maps list
00:00:00 (0000.65) | Objects processing end ok
00:00:00 (0000.65) | Processing Octane lights from LW scene.
00:00:00 (0000.65) | Number of LW lighs in scene: 1
00:00:00 (0000.65) | Reading light info - name: Light
00:00:00 (0000.65) | Found a Octane custom light Light
00:00:00 (0000.65) | Processing the light information ...
00:00:00 (0000.65) | Get light shape and geometry ...
00:00:00 (0000.65) | ... light shape processed succesfully
00:00:00 (0000.65) | Processing light material and emission nodes ...
00:00:00 (0000.65) | ... light source processed succesfully
00:00:00 (0000.65) | Processing light layerMap node ...
00:00:00 (0000.65) | ... light layerMap processed succesfully
00:00:00 (0000.65) | ... Light node processed succesfully.
00:00:00 (0000.65) | Setting the lights geometry group to the scene root geometry group, index 1
00:00:00 (0000.65) | Lights processing end ok
00:00:00 (0000.65) | Init the renderTarget
00:00:00 (0000.65) | Setting the root geometryGroup to the renderTarget
00:00:00 (0000.65) | Setting the default render target nodes
00:00:00 (0000.65) | Evaluating render target nodal editor
00:00:00 (0000.65) | + Processing the ThinLensCamera node
00:00:00 (0000.65) | + Processing the DayLightEnvironment node
00:00:00 (0000.65) | + Processing the Imager node
00:00:00 (0000.65) | + Processing the DirectLighting node
00:00:00 (0000.65) * OCTANE API MSG: Tried to access pin via an invalid ID P_AI_LIGHT_STRENGTH (385)
00:00:00 (0000.65) * OCTANE API MSG: Tried to access null node pin
00:00:00 (0000.65) * OCTANE API MSG: Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FFF5FAF2A30)
00:00:00 (0000.65) | + Processing the PortProcessing node
00:00:00 (0000.65) | Render target nodal editor evaluated succesfully
00:00:00 (0000.65) | Get or update scene camera
00:00:00 (0000.65) | Camera type is THINLENS_CAMERA
00:00:00 (0000.65) | IPR: set IPR camera options
00:00:00 (0000.65) | Removing the old camera motion blur data
00:00:00 (0000.65) | Removing the old objects motion blur data
00:00:00 (0000.65) | Removing the old objects deformations motion blur data
00:00:00 (0000.65) | Removing the old lights motion blur data
00:00:00 (0000.65) | Scene loaded
00:00:00 (0000.65) | Render resolution: 640 x 360
00:00:00 (0000.65) | IPR: scene loaded
00:00:00 (0000.65) | IPR: Enable IPR events processing
00:00:00 (0000.65) | IPR: init rendering
00:00:00 (0000.65) | IPR: set image callback
00:00:00 (0000.65) | Render scene, set renderTarget and update
00:00:00 (0000.65) | ... first update
00:00:00 (0000.65) | ... setRenderPriority
00:00:00 (0000.65) | ... RenderPriority set to 0
00:00:00 (0000.65) | ... set Motion Blur parameters
00:00:00 (0000.65) | ... setRenderTargetNode
00:00:00 (0000.91) | ... second update
00:00:00 (0000.91) | ... isRenderingPaused
00:00:00 (0000.91) | Render setup Ok.
00:00:00 (0000.91) | [profile] Function "LWOctane_renderScene" over "" execution time: 0.255 seconds
00:00:00 (0000.91) | IPR: enter into the rendering loop
00:00:01 (0001.17) * OCTANE API MSG: CUDA error 999 on device 2: unknown error
00:00:01 (0001.17) * OCTANE API MSG: -> failed to link file
00:00:01 (0001.17) * OCTANE API MSG: device 2: failed to load OSL shader code:
error : Multiple definition of 'cuSptStatistics' in 'cuda_texturenode', first defined in 'snippets_internal'
00:00:01 (0001.17) * OCTANE API MSG: device 2: failed to compile module 0
00:00:01 (0001.17) |
00:00:01 (0001.17) | ++++++++++++++++++++++++++
00:00:01 (0001.17) | +++ IPR RENDER FAILURE +++ processing the failure callback
00:00:01 (0001.18) | IPR: reset image callback
00:00:01 (0001.18) | IPR: wait for the getPreviewImage function
00:00:01 (0001.18) * OCTANE API MSG: CUDA error 999 on device 1: unknown error
00:00:01 (0001.18) * OCTANE API MSG: -> failed to link file
00:00:01 (0001.18) * OCTANE API MSG: device 1: failed to load OSL shader code:
00:00:01 (0001.18) * OCTANE API MSG: device 1: failed to compile module 0
00:00:01 (0001.20) * OCTANE API MSG: CUDA error 999 on device 0: unknown error
00:00:01 (0001.20) * OCTANE API MSG: -> failed to link file
00:00:01 (0001.20) * OCTANE API MSG: device 0: failed to load OSL shader code:
00:00:01 (0001.20) * OCTANE API MSG: device 0: failed to compile module 0
00:00:01 (0001.28) | IPR: free the OpenGL buffers
00:00:01 (0001.28) | IPR: rendering done
00:00:03 (0003.10) | IPR: close the IPR preview window
00:00:03 (0003.10) | IPR: finish render thread command
00:00:03 (0003.10) | IPR: abort render thread command
00:00:03 (0003.10) | Stop rendering scene ...
00:00:03 (0003.19) | ... Rendering stopped
00:00:03 (0003.19) | IPR: abort render thread command finished
00:00:03 (0003.19) | Close and free scene, free buffer: 0, reset scene: 1
00:00:03 (0003.19) | ... setRenderTargetNode(NULL)
00:00:03 (0003.19) | ... update()
00:00:03 (0003.19) | ... getRootNodeGraph()->clear()
00:00:03 (0003.19) | Scene closed
00:00:03 (0003.19) | IPR: free the snapshots system
00:00:03 (0003.19) | IPR: IPR preview window closed
00:00:03 (0003.19) | Octane Render for Lightwave, end of log system
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
wireframex
FYI --> no pb with Nvidia 417.71
Cheers
Phil
Main Computer:
wildpeaks
Can confirm: Octane didn't render anymore after driver update, but reinstalling 417.71 fixed it (and it's not Lightwave-specific as it was happening with the 3dsmax plugin as well).
KVNOODLES
wildpeaks wrote:Can confirm: Octane didn't render anymore after driver update, but reinstalling 417.71 fixed it (and it's not Lightwave-specific as it was happening with the 3dsmax plugin as well).
Same issue here but Octane 3.07 works perfectly, I suppose it's affecting only 4.0 and 2018 versions...
AndyM1969
There ia an announcement in the main forum and the Otoy Facebook group.
DO NOT UPDATE to latest drivers, they have broken Octane.
As a personal note I never update for at least two weeks to allow these issues to be resolved.
paride4331
Hi guys,
viewtopic.php?p=356426#p356426
Return to “Lightwave 3D”
