Cinema 4D version 2018.1-RC1 (Test version)
Kalua
I've been playing with blend material and I found a issue: not sure if it's supposed to work like that but when I got a diffuse shader with emitter blended with another material, the light doesn´t behave as usual.
Look at the picture.
Thanks for all the good work, Aoktar!
Cheers!
PS: Like mentioned by max383, it also happens with MIX materials.
C4D 2025.1.1 Octane 2025.2.1 v1.5.1, <<2 X 3090 + NVlink>>, Windows 10, X399, AMD TR 1950X, 128 GB RAM, NVIDIA SD 552.22
Kalua wrote:I've been playing with blend material and I found a issue: not sure if it's supposed to work like that but when I got a diffuse shader with emitter blended with another material, the light doesn´t behave as usual.
Cheers!
It's coming from a possible bug from the renderer. We'll look in to that.. Thanks!
bagel
Aoktar,
Any word on that light linking + displacement issue? Were you able to reproduce?
bagel wrote:Aoktar,
I'm not sure what's the problem you mean! I cannot see any problems for light linking as you reported in previous posts. Please send me a scene for light linking+displacement issue with description! Thanks!
bagel
I did, that same day, please check your inbox.
bagel wrote:I did, that same day, please check your inbox.
Yeah I've tried that but cannot understand what's problem. Light id2 is disabled from object tag and you cannot see effect of light because of that, isn't?
bagel
When the object had a material with displacement and you disable light I'd 2, it doesn't apply. The moment you disconnect the displacement in the node editor, it works properly again. I was able to reproduce it in a new project as well.
bagel
Well crap... It works now. Granted, I'm on a new machine. I don't know what to say other than sorry for being a pain, Aoktar. Thanks for all your hard work.
cjadams
Ok. im at a loss here... Ive tried both builds "regular" and "studio" no luck the plugin won't log in.
I have done the V3 to V4 upgrade.. and also bought AA for 199... I don't see a C4d plugin in downloads so i came here to see if it just wasn't listed.
Now i tried the latest beta ones from at the beginning of the thread and i get an error looking for enterprise.. also why it says i have 2 is beyond me?
Is that for extra render slave or something???
cjadams wrote:Ok. im at a loss here... Ive tried both builds "regular" and "studio" no luck the plugin won't log in.
Please install the regular commercial version, not the Studio subscription version:
https://render.otoy.com/customerdownloa ... Macosx.zip
ciao Beppe
Return to “Releases”
