Since Octane does not have a light converter, we have to use the Vray light converter and then convert it into Octane when importing FBXs. This used to work properly, but now seems broken.
I used to be able to convert a rectangular light using this process, but now all lights are converted to point lights. They are also all pointing down now, which is incorrect.
Have a look at this scene. All the rectangular lights have been converted to points. All the lights that are supposed to point sideways now point downwards.
Another thing, I wish I could control whether the light is visible by default instead of changing them all manually. I do not usually want to show this light.
Vray Light Conversion - New Problems
- paride4331
Hi Paride,
I certainly found two faults with my experience last Friday:
-The are shapes are gone and lights are transformed to point lights
-Light that do not point downwards are converted by Octane into lights that point downwards
I will try to set up a test file and screenshots when I get to work. Fro your test file, I suggest getting some files that are not pointing downwards as well.
Actually, I suggest converting a Revit file with proper lighting to see our workflow. PS- we would not be doing this 3ds Max workflow if the Revit plugin just worked with lights properly.
- paride4331
Hi Samuel,
please, could you better explain your workflow?
you prepare your scene using: (Revit and Vray?)
you export your file to max using: (.FBX?)
then do you convert imported scene?
I would like to help you but I cannot follow what you were saying.
- paride4331
Hi SamuelAB,
Is this your workflow?
viewtopic.php?f=27&t=70395#p355459
could you share a .FBX from Revit you made?
Hi Paride,
My workflow is:
-Export FBX From Revit
-Import into 3ds Max
-Switch to Vray
-Select lights and convert to Vray lights
-Using Universal Material Converter, convert materials to Standard (https://www.3dstudio.nl/webshop/product ... -converter)
-Switch to Octane and convert the whole scene materials and lights
*I wish Octane has a light converter so that I would not have to use the Vray expired trial converter*
Here are two FBXs from Revit before any of these conversions
My workflow is:
-Switch to Vray
There are the error messages from converting this small scene, with extra logs enabled:
[O3m] !! Failed to convert material <01 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <02 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <03 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <04 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <05 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <06 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <Solid Glass>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <Ceramic>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <Wall Paint>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <Metal>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <11 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <12 - Car Paint>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <13 - Brushed Metal>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <14 - Polished Aluminum>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <15 - Glossy Plastic>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <16 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <17 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <18 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <19 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <20 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <21 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <22 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <23 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <24 - Default>, unknown class <Physical Material>, Class_ID(0x3d6b1cec, 0xdeadc001) sid=3072..
[O3m] !! Failed to convert material <Mur par défaut>, unknown class <Autodesk Generic>, Class_ID(0x1ed415e4, 0x213daaf8) sid=3072..
[O3m] !! Failed to convert material <Generic>, unknown class <Autodesk Generic>, Class_ID(0x1ed415e4, 0x213daaf8) sid=3072..
[O3m] !! Failed to convert material <Verre blanc à forte luminosité>, unknown class <Autodesk Generic>, Class_ID(0x1ed415e4, 0x213daaf8) sid=3072..
[O3m] New octane material Converted : <Object> from class <VRayIES>
[O3m] New octane material Converted : <MultiMat_0> from class <Multi/Sub-Object>
[O3m] !! Failed to convert material <Lentille acrylique>, unknown class <Autodesk Generic>, Class_ID(0x1ed415e4, 0x213daaf8) sid=3072..
[O3m] New octane material Converted : <MultiMat_1> from class <Multi/Sub-Object>
'About visible/invisible, i could ask to developers to add that option in Vray conversion option panel.'
That would be great! A way to mass modify lights would be great as well. Something like the 3ds Max Light Lister.
My current model has 800+ lights and I'm not really feeling the hunt and click adventure of making them all invisible
I've tried converting the Vray lights with Octane 3.08.3 and got the same results where a rectangular source becomes a point source.
I`ve done this successfully in the past, but it seems tohave broken at some point. Any help would be appreciated.
If I can get the volumetric lights to convert, I will be pretty happy!
