Issue discovered : Emissive on a diffuse material don't show / render when I use a mix Mat.
Works fine in 4, and works fine with specular emission inside the medium channel.
Hope it helped.
Yeah, it also crashes on Windows 10. I'm running it on C4D R19 with an RTX 2070, and it crashes right after I make the vectron object.SRCOBB wrote:I've found that trying to use vectron freezes C4D for me (OS X High Sierra 10.13.6). At least one other user has confirmed the same.
The program was freezing as soon as I tried to modify the vectron object in any way with the live viewer open. I then found that I could create an object, set it to mandelbub, and change the power BEFORE rendering in live viewer, then I was able to see and move around the object, but as soon as I tried to change parameters (I tried to increase the power) it froze again. Anybody else?
it's working as I could checked. What's the problem?bagel wrote:Not sure if it's been mentioned already, but light linking appears not to work in this version. Same c4d scene works fine in 4.01 R2.
I appreciate the reply. I had to redo my scene. Seemed like something was broken in the scene file and it would no longer export to Octane for render. There was no way I could salvage it. (I'm actually not blaming Octane for this, I think something went screwy with C4D or my filesystem.) When I get to that point, I'll post my settings and results for you.aoktar wrote:it's working as I could checked. What's the problem?bagel wrote:Not sure if it's been mentioned already, but light linking appears not to work in this version. Same c4d scene works fine in 4.01 R2.
First be sure that's not a mistake on your side. And pls send me a scene if you have it reproducible.bagel wrote:Here we go! Happening again. This worked when I swapped out for the 4.01.1 R2 plugin. It does not appear to work in 2018 RC1. I turned off all of the other lights in the scene.
The light is not supposed to hit the back wall. Just the text and logo. More critical info:
Cinema 4D R20.030
Octane C4D Plugin 2018.1-RC1
Windows 10
Pile of 1080Ti's
