by KVNOODLES » Thu Dec 20, 2018 11:10 pm
KVNOODLES
My scene contains a ground plane and a sphere. And my resolution is 1080p.
here is my log :
00:00:00 (0000.00) | Log started Fri Dec 21 00:01:26 2018
00:00:00 (0000.00) | Octane Render for Lightwave by Juanjo González. Build 4.01.1.0 (Build date: Dec 14 2018 17:04:48)
00:00:00 (0000.08) | Compiled for LightWave 2018.0 (build 3065)
00:00:00 (0000.08) | Compiled using the Octane API 4.01.1
00:00:00 (0000.08) | Running on LightWave 2018.0 (build: 3070)
00:00:00 (0000.08) | Running on Octane DLL 4010100
00:00:00 (0000.08) | System: GenuineIntel unknown, 2905 Mhz., 16 cores
00:00:00 (0000.08) | OS: Windows 8 64-bit
00:00:00 (0000.08) | IPR: init snapshoths system
00:00:00 (0000.08) | IPR: init IPR preview window
00:00:00 (0000.23) | IPR: init a buffer snapshot
00:00:00 (0000.24) | IPR: buffer snapshot ok
00:00:00 (0000.24) | IPR: Init render thread
00:00:00 (0000.24) | IPR: reloading scene - render thread waiting for events before init rendering
00:00:00 (0000.34) | IPR: loading scene
00:00:00 (0000.34) | IPR: Disable IPR events processing
00:00:00 (0000.39) |
00:00:00 (0000.39) | Init scene
00:00:00 (0000.39) | Init the root geometryGroup
00:00:00 (0000.39) | Processing the motion blur data
00:00:00 (0000.39) | Get the scene motion blur settings
00:00:00 (0000.39) | Motion blur disabled, computing only one time sample
00:00:00 (0000.39) | Processing time sample 1 of 1, time: 0.000000
00:00:00 (0000.39) | Get camera motion blur data
00:00:00 (0000.39) | * position: 0.000000 0.750000 5.899998
00:00:00 (0000.39) | * target: 0.000000 0.750000 -94.100002
00:00:00 (0000.39) | * fov: 29.862833
00:00:00 (0000.39) | Get Objects motion blur data
00:00:00 (0000.39) | Object New Ground Plane Object transformation matrix:
00:00:00 (0000.39) | 10.000000 0.000000 -0.000000 0.000000
00:00:00 (0000.39) | 0.000000 10.000000 0.000000 0.000000
00:00:00 (0000.39) | -0.000000 -0.000000 10.000000 -0.000000
00:00:00 (0000.39) | Object New Sphere Object transformation matrix:
00:00:00 (0000.39) | 1.000000 0.000000 -0.000000 0.000000
00:00:00 (0000.39) | 0.000000 1.000000 0.000000 0.625000
00:00:00 (0000.39) | -0.000000 -0.000000 1.000000 -0.000000
00:00:00 (0000.39) | Get vertex deformations motion blur data
00:00:00 (0000.39) | Get Lights motion blur data
00:00:00 (0000.39) | Light Light transformation matrix:
00:00:00 (0000.39) | 0.707107 0.405580 -0.579228 -2.000000
00:00:00 (0000.39) | 0.000000 0.819152 0.573576 2.000000
00:00:00 (0000.39) | 0.707107 -0.405580 0.579228 2.000000
00:00:00 (0000.39) | Motion blur data ready
00:00:00 (0000.39) | Processing objects list from LW scene. FIRST PASS
00:00:00 (0000.39) | Number of LW objects: 2
00:00:00 (0000.39) | -> Reading scene UV Maps list
00:00:00 (0000.39) | --> Detected 0 UVMaps in scene
00:00:00 (0000.39) | Processing object: 10000000, name: New Ground Plane Object
00:00:00 (0000.39) | Object New Ground Plane Object is a LW object without clones, we must add the mesh to Octane database
00:00:00 (0000.39) | Searching if FiberFX is available in this object
00:00:00 (0000.39) | >>> Processing the number of valid polygons
00:00:00 (0000.39) | >>> This object has 1 of 1 valid polygons
00:00:00 (0000.40) | >>> Adding a new mesh to Octane
00:00:00 (0000.40) | >>> Mesh points: 4, valid polygons: 1
00:00:00 (0000.40) | ----> Searching UV maps in this object
00:00:00 (0000.40) | ----> No UV maps found in this object
00:00:00 (0000.40) | [profile] Function "LWOctane_getVMap" over "" execution time: 0.000 seconds
00:00:00 (0000.40) | >>> Processing vertex per poly array
00:00:00 (0000.40) | [profile] Function "LWOctane_getVertsPerPoly" over "" execution time: 0.000 seconds
00:00:00 (0000.40) | >>> Processing vertex list
00:00:00 (0000.40) | [profile] Function "LWOctane_addVertex" over "" execution time: 0.000 seconds
00:00:00 (0000.40) | +++ Searching object materials
00:00:00 (0000.40) | +++ Found 1 materials inside New Ground Plane Object
00:00:00 (0000.40) | +++ Material 0 ID: Ground Plane
00:00:00 (0000.40) | +++ Searching in the object materials for UVMAP nodes
00:00:00 (0000.40) | >>> Searching UVMAP node inside surface Ground Plane
00:00:00 (0000.40) | >>> This material doesn't have a valid UVMAP node
00:00:00 (0000.40) | >>> Processing polygon data
00:00:00 (0000.40) | [profile] Function "LWOctane_addPolData" over "" execution time: 0.000 seconds
00:00:00 (0000.40) | >>> Mesh added, evaluating it
00:00:00 (0000.40) | [profile] Function "LWOctane_addMesh" over "" execution time: 0.001 seconds
00:00:00 (0000.40) | +++ Processing object materials
00:00:00 (0000.40) | > Filtering 1 materials in 1 polygons
00:00:00 (0000.40) | > Filtering 1 materials in 0 hairs
00:00:00 (0000.40) | Used materials in this object: 1
00:00:00 (0000.40) | +++ Processing material Ground Plane
00:00:00 (0000.40) | +++ This material has a valid Octane nodal shading tree, processing it ...
00:00:00 (0000.40) | --> Procesing a new DiffuseMaterial node
00:00:00 (0000.40) | +++ End of materials processing
00:00:00 (0000.40) | Searching FiberFX hair materials
00:00:00 (0000.40) | +++ Processing object layer maps functions
00:00:00 (0000.40) | --> Get object global dissolve value: 0.000000, state 0
00:00:00 (0000.40) | [profile] Function "LWOctane_addGeom" over "New Ground Plane Object" execution time: 0.007 seconds
00:00:00 (0000.40) | Processing object: 10000001, name: New Sphere Object
00:00:00 (0000.40) | Object New Sphere Object is a LW object without clones, we must add the mesh to Octane database
00:00:00 (0000.40) | Searching if FiberFX is available in this object
00:00:00 (0000.40) | >>> Processing the number of valid polygons
00:00:00 (0000.40) | >>> This object has 4752 of 4752 valid polygons
00:00:00 (0000.40) | >>> Mesh points: 2644, valid polygons: 4752
00:00:00 (0000.40) | [profile] Function "LWOctane_getVertsPerPoly" over "" execution time: 0.001 seconds
00:00:00 (0000.40) | [profile] Function "LWOctane_addVertex" over "" execution time: 0.001 seconds
00:00:00 (0000.40) | +++ Found 1 materials inside New Sphere Object
00:00:00 (0000.40) | +++ Material 0 ID: Sphere
00:00:00 (0000.40) | >>> Searching UVMAP node inside surface Sphere
00:00:00 (0000.41) | [profile] Function "LWOctane_addPolData" over "" execution time: 0.004 seconds
00:00:00 (0000.41) | >>> Mesh added, evaluating it
00:00:00 (0000.41) | [profile] Function "LWOctane_addMesh" over "" execution time: 0.007 seconds
00:00:00 (0000.41) | +++ Processing object materials
00:00:00 (0000.41) | > Filtering 1 materials in 4752 polygons
00:00:00 (0000.41) | > Filtering 1 materials in 0 hairs
00:00:00 (0000.41) | Used materials in this object: 1
00:00:00 (0000.41) | +++ Processing material Sphere
00:00:00 (0000.41) | +++ This material has a valid Octane nodal shading tree, processing it ...
00:00:00 (0000.41) | --> Procesing a new DiffuseMaterial node
00:00:00 (0000.41) | +++ End of materials processing
00:00:00 (0000.41) | Searching FiberFX hair materials
00:00:00 (0000.41) | +++ Processing object layer maps functions
00:00:00 (0000.41) | --> Get object global dissolve value: 0.000000, state 0
00:00:00 (0000.41) | [profile] Function "LWOctane_addGeom" over "New Sphere Object" execution time: 0.009 seconds
00:00:00 (0000.41) | Processing objects list from LW scene. SECOND PASS
00:00:00 (0000.41) | Second pass check for object 10000000
00:00:00 (0000.41) | Object New Ground Plane Object has the native Lightwave instancer plugin with 0 instances
00:00:00 (0000.41) | Processing instances ...
00:00:00 (0000.41) | Second pass check for object 10000000 ok.
00:00:00 (0000.41) | Second pass check for object 10000001
00:00:00 (0000.41) | Object New Sphere Object has the native Lightwave instancer plugin with 0 instances
00:00:00 (0000.41) | Second pass check for object 10000001 ok.
00:00:00 (0000.41) | Setting the objects geometry group to the scene root geometry group, index 0
00:00:00 (0000.41) | Setting the instances geometry group to the scene root geometry group, index 2
00:00:00 (0000.41) | -> Releasing scene UV Maps list
00:00:00 (0000.41) | Objects processing end ok
00:00:00 (0000.41) | Processing Octane lights from LW scene.
00:00:00 (0000.41) | Number of LW lighs in scene: 1
00:00:00 (0000.41) | Reading light info - name: Light
00:00:00 (0000.41) | Light Light, type distant, not supported by Octante currently
00:00:00 (0000.41) | Setting the lights geometry group to the scene root geometry group, index 1
00:00:00 (0000.41) | Lights processing end ok
00:00:00 (0000.41) | Init the renderTarget
00:00:00 (0000.41) | Setting the root geometryGroup to the renderTarget
00:00:00 (0000.41) | Setting the default render target nodes
00:00:00 (0000.41) | Evaluating render target nodal editor
00:00:00 (0000.41) | + Processing the ThinLensCamera node
00:00:00 (0000.41) | + Processing the DayLightEnvironment node
00:00:00 (0000.41) | --> Procesing a new VolumeMedium node
00:00:00 (0000.41) | + Processing the Imager node
00:00:00 (0000.41) | + Processing the PathTracing node
00:00:00 (0000.41) * OCTANE API MSG: Tried to access pin via an invalid ID P_AI_LIGHT_STRENGTH (385)
00:00:00 (0000.41) * OCTANE API MSG: Tried to access null node pin
00:00:00 (0000.41) * OCTANE API MSG: Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 00007FF983A9E240)
00:00:00 (0000.41) | Render target nodal editor evaluated succesfully
00:00:00 (0000.41) | Get or update scene camera
00:00:00 (0000.41) | Camera type is THINLENS_CAMERA
00:00:00 (0000.41) | IPR: set IPR camera options
00:00:00 (0000.41) | Removing the old camera motion blur data
00:00:00 (0000.41) | Removing the old objects motion blur data
00:00:00 (0000.41) | Removing the old objects deformations motion blur data
00:00:00 (0000.41) | Removing the old lights motion blur data
00:00:00 (0000.41) | Scene loaded
00:00:00 (0000.41) | Render resolution: 1920 x 1080
00:00:00 (0000.41) | IPR: scene loaded
00:00:00 (0000.41) | IPR: Enable IPR events processing
00:00:00 (0000.41) | IPR: init rendering
00:00:00 (0000.41) | IPR: set image callback
00:00:00 (0000.41) | Render scene, set renderTarget and update
00:00:00 (0000.41) | ... first update
00:00:00 (0000.41) | ... setRenderPriority
00:00:00 (0000.41) | ... RenderPriority set to 0
00:00:00 (0000.41) | ... set Motion Blur parameters
00:00:00 (0000.41) | ... setRenderTargetNode
00:00:00 (0000.72) | ... second update
00:00:00 (0000.72) | ... isRenderingPaused
00:00:00 (0000.72) | Render setup Ok.
00:00:00 (0000.72) | [profile] Function "LWOctane_renderScene" over "" execution time: 0.310 seconds
00:00:00 (0000.72) | IPR: enter into the rendering loop
00:00:01 (0001.48) | IPR: processing image callback
00:00:01 (0001.48) | Reading preview image
00:00:01 (0001.48) | ... Get sampling information
00:00:01 (0001.48) | ... Statistics: 1 of 512 samples, 0 sec, 4.22 Ms/sec
00:00:01 (0001.48) | ... Get buffers resolution
00:00:01 (0001.48) | ... Resolution: 1600 900
00:00:01 (0001.48) | ... Check compositing
00:00:01 (0001.48) | ... Compositing 0
00:00:01 (0001.48) | ... Check sizes for IPR
00:00:01 (0001.48) | ... Reading frame buffer
00:00:01 (0001.49) | Reading preview image successfully
00:00:01 (0001.49) | [profile] Function "GetPreviewImage" over "" execution time: 0.011 seconds
00:00:01 (0001.80) | IPR: processing image callback
00:00:01 (0001.80) | Reading preview image
00:00:01 (0001.80) | ... Get sampling information
00:00:01 (0001.80) | ... Statistics: 2 of 512 samples, 0 sec, 4.51 Ms/sec
00:00:01 (0001.80) | ... Get buffers resolution
00:00:01 (0001.80) | ... Resolution: 1600 900
00:00:01 (0001.80) | ... Check compositing
00:00:01 (0001.80) | ... Compositing 0
00:00:01 (0001.80) | ... Check sizes for IPR
00:00:01 (0001.80) | ... Reading frame buffer
00:00:01 (0001.83) | Reading preview image successfully
00:00:01 (0001.83) | [profile] Function "GetPreviewImage" over "" execution time: 0.027 seconds
00:00:01 (0001.98) | IPR: processing image callback
00:00:01 (0001.98) | Reading preview image
00:00:01 (0001.98) | ... Get sampling information
00:00:01 (0001.98) | ... Statistics: 3 of 512 samples, 0 sec, 5.45 Ms/sec
00:00:01 (0001.98) | ... Get buffers resolution
00:00:01 (0001.98) | ... Resolution: 1600 900
00:00:01 (0001.98) | ... Check compositing
00:00:01 (0001.98) | ... Compositing 0
00:00:01 (0001.98) | ... Check sizes for IPR
00:00:01 (0001.98) | ... Reading frame buffer
00:00:01 (0001.99) | Reading preview image successfully
00:00:01 (0001.99) | [profile] Function "GetPreviewImage" over "" execution time: 0.007 seconds
00:00:02 (0002.23) | IPR: processing image callback
00:00:02 (0002.23) | Reading preview image
00:00:02 (0002.23) | ... Get sampling information
00:00:02 (0002.23) | ... Statistics: 5 of 512 samples, 1 sec, 8.16 Ms/sec
00:00:02 (0002.23) | ... Get buffers resolution
00:00:02 (0002.23) | ... Resolution: 1600 900
00:00:02 (0002.23) | ... Check compositing
00:00:02 (0002.23) | ... Compositing 0
00:00:02 (0002.23) | ... Check sizes for IPR
00:00:02 (0002.23) | ... Reading frame buffer
00:00:02 (0002.24) | Reading preview image successfully
00:00:02 (0002.24) | [profile] Function "GetPreviewImage" over "" execution time: 0.007 seconds
00:00:02 (0002.37) | IPR: processing image callback
00:00:02 (0002.37) | Reading preview image
00:00:02 (0002.37) | ... Get sampling information
00:00:02 (0002.37) | ... Statistics: 6 of 512 samples, 1 sec, 8.34 Ms/sec
00:00:02 (0002.37) | ... Get buffers resolution
00:00:02 (0002.37) | ... Resolution: 1600 900
00:00:02 (0002.37) | ... Check compositing
00:00:02 (0002.37) | ... Compositing 0
00:00:02 (0002.37) | ... Check sizes for IPR
00:00:02 (0002.37) | ... Reading frame buffer
00:00:02 (0002.39) | Reading preview image successfully
00:00:02 (0002.39) | [profile] Function "GetPreviewImage" over "" execution time: 0.024 seconds
00:00:02 (0002.56) | IPR: processing image callback
00:00:02 (0002.56) | Reading preview image
00:00:02 (0002.56) | ... Get sampling information
00:00:02 (0002.56) | ... Statistics: 9 of 512 samples, 1 sec, 10.38 Ms/sec
00:00:02 (0002.56) | ... Get buffers resolution
00:00:02 (0002.56) | ... Resolution: 1600 900
00:00:02 (0002.56) | ... Check compositing
00:00:02 (0002.56) | ... Compositing 0
00:00:02 (0002.56) | ... Check sizes for IPR
00:00:02 (0002.56) | ... Reading frame buffer
00:00:02 (0002.59) | Reading preview image successfully
00:00:02 (0002.59) | [profile] Function "GetPreviewImage" over "" execution time: 0.025 seconds
00:00:02 (0002.78) | IPR: processing image callback
00:00:02 (0002.78) | Reading preview image
00:00:02 (0002.78) | ... Get sampling information
00:00:02 (0002.78) | ... Statistics: 13 of 512 samples, 1 sec, 12.35 Ms/sec
00:00:02 (0002.78) | ... Get buffers resolution
00:00:02 (0002.78) | ... Resolution: 1600 900
00:00:02 (0002.78) | ... Check compositing
00:00:02 (0002.78) | ... Compositing 0
00:00:02 (0002.78) | ... Check sizes for IPR
00:00:02 (0002.78) | ... Reading frame buffer
00:00:02 (0002.78) | Reading preview image successfully
00:00:02 (0002.78) | [profile] Function "GetPreviewImage" over "" execution time: 0.008 seconds
00:00:03 (0003.06) | IPR: processing image callback
00:00:03 (0003.06) | Reading preview image
00:00:03 (0003.06) | ... Get sampling information
00:00:03 (0003.06) | ... Statistics: 19 of 512 samples, 1 sec, 15.01 Ms/sec
00:00:03 (0003.06) | ... Get buffers resolution
00:00:03 (0003.06) | ... Resolution: 1600 900
00:00:03 (0003.06) | ... Check compositing
00:00:03 (0003.06) | ... Compositing 0
00:00:03 (0003.06) | ... Check sizes for IPR
00:00:03 (0003.06) | ... Reading frame buffer
00:00:03 (0003.07) | Reading preview image successfully
00:00:03 (0003.07) | [profile] Function "GetPreviewImage" over "" execution time: 0.008 seconds
00:00:03 (0003.19) | IPR: processing image callback
00:00:03 (0003.19) | Reading preview image
00:00:03 (0003.19) | ... Get sampling information
00:00:03 (0003.19) | ... Statistics: 23 of 512 samples, 2 sec, 17.08 Ms/sec
00:00:03 (0003.19) | ... Get buffers resolution
00:00:03 (0003.19) | ... Resolution: 1600 900
00:00:03 (0003.19) | ... Check compositing
00:00:03 (0003.19) | ... Compositing 0
00:00:03 (0003.19) | ... Check sizes for IPR
00:00:03 (0003.19) | ... Reading frame buffer
00:00:03 (0003.19) | Reading preview image successfully
00:00:03 (0003.19) | [profile] Function "GetPreviewImage" over "" execution time: 0.007 seconds
00:00:03 (0003.52) | IPR: processing image callback
00:00:03 (0003.52) | Reading preview image
00:00:03 (0003.52) | ... Get sampling information
00:00:03 (0003.52) | ... Statistics: 27 of 512 samples, 2 sec, 17.14 Ms/sec
00:00:03 (0003.52) | ... Get buffers resolution
00:00:03 (0003.52) | ... Resolution: 1600 900
00:00:03 (0003.52) | ... Check compositing
00:00:03 (0003.52) | ... Compositing 0
00:00:03 (0003.52) | ... Check sizes for IPR
00:00:03 (0003.52) | ... Reading frame buffer
00:00:03 (0003.52) | Reading preview image successfully
00:00:03 (0003.52) | [profile] Function "GetPreviewImage" over "" execution time: 0.008 seconds
00:00:04 (0004.14) | IPR: processing image callback
00:00:04 (0004.14) | Reading preview image
00:00:04 (0004.14) | ... Get sampling information
00:00:04 (0004.14) | ... Statistics: 47 of 512 samples, 3 sec, 23.13 Ms/sec
00:00:04 (0004.14) | ... Get buffers resolution
00:00:04 (0004.14) | ... Resolution: 1600 900
00:00:04 (0004.14) | ... Check compositing
00:00:04 (0004.14) | ... Compositing 0
00:00:04 (0004.14) | ... Check sizes for IPR
00:00:04 (0004.14) | ... Reading frame buffer
00:00:04 (0004.15) | Reading preview image successfully
00:00:04 (0004.15) | [profile] Function "GetPreviewImage" over "" execution time: 0.007 seconds
00:00:05 (0005.62) | IPR: processing image callback
00:00:05 (0005.62) | Reading preview image
00:00:05 (0005.62) | ... Get sampling information
00:00:05 (0005.62) | ... Statistics: 79 of 512 samples, 4 sec, 25.86 Ms/sec
00:00:05 (0005.62) | ... Get buffers resolution
00:00:05 (0005.62) | ... Resolution: 1600 900
00:00:05 (0005.62) | ... Check compositing
00:00:05 (0005.62) | ... Compositing 0
00:00:05 (0005.62) | ... Check sizes for IPR
00:00:05 (0005.62) | ... Reading frame buffer
00:00:05 (0005.63) | Reading preview image successfully
00:00:05 (0005.63) | [profile] Function "GetPreviewImage" over "" execution time: 0.007 seconds
00:00:07 (0007.04) | IPR: processing image callback
00:00:07 (0007.04) | Reading preview image
00:00:07 (0007.04) | ... Get sampling information
00:00:07 (0007.04) | ... Statistics: 111 of 512 samples, 5 sec, 27.41 Ms/sec
00:00:07 (0007.04) | ... Get buffers resolution
00:00:07 (0007.04) | ... Resolution: 1600 900
00:00:07 (0007.04) | ... Check compositing
00:00:07 (0007.04) | ... Compositing 0
00:00:07 (0007.04) | ... Check sizes for IPR
00:00:07 (0007.04) | ... Reading frame buffer
00:00:07 (0007.05) | Reading preview image successfully
00:00:07 (0007.05) | [profile] Function "GetPreviewImage" over "" execution time: 0.007 seconds
00:00:09 (0009.34) | IPR: processing image callback
00:00:09 (0009.34) | Reading preview image
00:00:09 (0009.34) | ... Get sampling information
00:00:09 (0009.34) | ... Statistics: 175 of 512 samples, 8 sec, 30.98 Ms/sec
00:00:09 (0009.34) | ... Get buffers resolution
00:00:09 (0009.34) | ... Resolution: 1600 900
00:00:09 (0009.34) | ... Check compositing
00:00:09 (0009.34) | ... Compositing 0
00:00:09 (0009.34) | ... Check sizes for IPR
00:00:09 (0009.34) | ... Reading frame buffer
00:00:09 (0009.35) | Reading preview image successfully
00:00:09 (0009.35) | [profile] Function "GetPreviewImage" over "" execution time: 0.007 seconds
00:00:11 (0011.63) | IPR: processing image callback
00:00:11 (0011.63) | Reading preview image
00:00:11 (0011.63) | ... Get sampling information
00:00:11 (0011.63) | ... Statistics: 239 of 512 samples, 10 sec, 36.22 Ms/sec
00:00:11 (0011.63) | ... Get buffers resolution
00:00:11 (0011.63) | ... Resolution: 1600 900
00:00:11 (0011.63) | ... Check compositing
00:00:11 (0011.63) | ... Compositing 0
00:00:11 (0011.63) | ... Check sizes for IPR
00:00:11 (0011.63) | ... Reading frame buffer
00:00:11 (0011.63) | Reading preview image successfully
00:00:11 (0011.63) | [profile] Function "GetPreviewImage" over "" execution time: 0.007 seconds
00:00:14 (0014.73) | IPR: processing image callback
00:00:14 (0014.73) | Reading preview image
00:00:14 (0014.73) | ... Get sampling information
00:00:14 (0014.73) | ... Statistics: 335 of 512 samples, 13 sec, 41.92 Ms/sec
00:00:14 (0014.73) | ... Get buffers resolution
00:00:14 (0014.73) | ... Resolution: 1600 900
00:00:14 (0014.73) | ... Check compositing
00:00:14 (0014.73) | ... Compositing 0
00:00:14 (0014.73) | ... Check sizes for IPR
00:00:14 (0014.73) | ... Reading frame buffer
00:00:14 (0014.74) | Reading preview image successfully
00:00:14 (0014.74) | [profile] Function "GetPreviewImage" over "" execution time: 0.007 seconds
