OctaneRender™ 4.01 for LightWave™ - stable build 4.01.1.0
juanjgon
This is the latest stable release of the OctaneRender™ 4.01 for LightWave™ plugin version 4.01.1.0, available for LightWave 11.6, 2015.3 and 2018.0 Windows x64 and OSX. This build has been compiled using the Octane 4.01.1 core.
License upgrade
Unless you have a subscription license, you will have to upgrade your version 3 licenses to version 4. This upgrade is free and can be done via these 4 steps:
To use this version, you need a GPU of compute model 3.0 or higher. Support for Fermi GPUs (like GTX 4xx and 5xx) has been dropped. Also make sure you use a driver of version 387 or higher and if you are working on Mac OS that have a CUDA driver installed that supports at least CUDA 9.1.
New features
To learn more about the new features and improvements of OctaneRender 4, please check out our blog post, but this a quick list of the main new features that have been added:
  • Overhauled geometry engine that dramatically reduces compilation times.
  • Support for out-of-core geometry.
  • AI Light: Improved sampling of emitters, which is a lot more effective than the old method if you have many small emitters that have only a fairly local effect.
  • AI Denoiser: Cleans up your render, which can dramatically cut render times.
  • Global light inclusion/exclusion.
  • Light linking: Allows the inclusion/exclusion of light IDs in the object layer nodes, which can be used to control the direct influence of emitters on objects.
  • Universal material: Merges the properties of the diffuse, glossy, specular and metal materials into one material.
  • UDIM support via the new image tile mode in the texture image node.
  • Dirt support in the info channel passes / kernel.
  • Overall performance improvements in the render engine and in loading HDR and OBJ files.
  • Support to capture direct and indirect light separately in the light render passes.
  • Support for emission on sphere primitives.
  • Planetary environment node.
Release 4.01.1.0 regular license
https://render.otoy.com/customerdownloa ... _Win64.zip
https://render.otoy.com/customerdownloa ... ve_OSX.zip
Release 4.01.1.0 subscription license
https://render.otoy.com/customerdownloa ... n64_vr.zip
https://render.otoy.com/customerdownloa ... OSX_vr.zip
Release 4.01.1.0 demo builds
https://render.otoy.com/plugindownloads ... 4_demo.zip
https://render.otoy.com/plugindownloads ... X_demo.zip
Standalone 4.01.1 version for the network rendering nodes
https://render.otoy.com/customerdownloa ... _1_win.exe
https://render.otoy.com/customerdownloa ... _macos.dmg
Release Notes:
RELEASE 4.01.1.0
* PLUGIN FEATURES:
- Refactoring of the IPR window resize functions to make them faster and avoid crashes and freezes.
- Faster switching of the IPR "Half Res" mode.
- Added the planetary environment node.
* OCTANE FEATURES AND BUGS FIXED:
- Improved the planetary environment by replacing the planetary axis and angle input pins with latitude and longitude pins, to allow you defining the correct orientation of the planet underneath your location that can be matched against the coordinates in the sun direction node.
- Improved memory management during progressive scene data updates, when out-of-core is used to fix a performance regression observed with various scenes.
- Removed the fast GPU upload which caused issues on systems that connected via PCIe risers/expanders (see viewtopic.php?p=351110#p351110). It didn't make much of a difference in most cases.
- Fixed CUDA failure in the baking camera when rendering a scene with animated meshes.
- Fixed hot pixels and incorrect light distributions in scenes with portals that have AI light enabled.
- Fixed global light exclusion of the environment if the scene contains portals (see viewtopic.php?p=351802#p351802).
- Fixed clamping of post-effects in the denoised main pass.
- Fixed artifacts in scenes of scaled meshes that use displacement, which became most visible in the AO info channel kernel.
- Fixed wireframe rendering when using the baking camera.
- Fixed incorrect attribute access when a scene with volumes is rendered using the baking camera.
- Fixed bug that caused the denoiser to not start on the very first frame / render (see viewtopic.php?p=352129#p352129)
- Fixed incorrect rendering of shadow catcher materials in the denoiser main pass (see viewtopic.php?p=352596#p352596).
- Fixed filtering out of daemons that run on the same machine as the net render master.
- OSL: Fixed crash when using getattribute("camera:fov", fov) in an OSL shader
Happy rendering,
Your OTOY Team
Lewis
Thanks Juan.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
3dworks
thanks for the update, juanjo!
the link for the OSX standalone app/node does not work here...
UPDATE: you can download from here : viewtopic.php?f=24&t=69925&start=10#p352717
AndyM1969
Outstanding job Juanjo, thank you
FrankPooleFloating
YES!! Thanks J! :D
Edit: Hey J, somewhere along the way you must have fixed that crash bug when turning instances (hundreds of thousands or more) back on with IPR open! Nice!.. Also, I'm scaling IPR all over the dang place with no crashes! Sweet!
nico_cad
why rhis response for me?
You currently have no eligible products attached to your account. :twisted: :twisted:
juanjgon
3dworks wrote:thanks for the update, juanjo!
Thanks! I've updated the download link on this topic.
juanjgon
nico_cad wrote:why rhis response for me?
When do you get this error, while trying to download the plugin files? Perhaps you are not logged with your account user or something like that.
pixym
Hi Juanjo,
Due to a hardware issue I had to re-install Windows and Lightwave 2015.3 on my PC.
My main and BIG issue right now is I can't add Octane 4.00 2015.3 plug-in O_o
Whatever I try to do gives me the message : "Plugins were not found or could not be added". I am really annoyed. Can you help me to resolve this issue? any clue?
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
pixym
Can somebody tell me if CUDA Toolkit has to be installed first ?
https://developer.nvidia.com/cuda-downl ... e=exelocal
Return to “Lightwave 3D”
