Issue Downloading materials from LiveDB Houdini
Forums: Issue Downloading materials from LiveDB Houdini
Houdini Integrated Plugin
Postby deltarod » Mon Dec 10, 2018 7:14 pm
deltarod Mon Dec 10, 2018 7:14 pm
Hello dears,
I get error messages when trying to download materials from the LiveDB in Houdini.
Somebody else have the same issue?
*** OCTANE API MSG: Could not load 'assets\chestnut Rushmore.jpg:rgba'.
*** OCTANE API MSG: FileName::toJuceFile() can be called only on absolute file names
*** OCTANE API MSG: Could not load 'assets\chestnut Rushmore spec bump.jpg:mono'.
Thanks.
deltarod
Re: Issue Downloading materials from LiveDB Houdini
Postby juanjgon » Mon Dec 10, 2018 9:42 pm
juanjgon Mon Dec 10, 2018 9:42 pm
What is your LiveDB textures directory configuration? You have these options in the plugin options panel. By default, it is $JOB/tex ... perhaps you have a problem to work with this directory because it is not available.
juanjgon
Postby deltarod » Mon Dec 10, 2018 10:33 pm
deltarod Mon Dec 10, 2018 10:33 pm
Yes thanks Juanjo, that seems to be the problem.
How could I make the directory available?
Regards.
*** OCTANE API MSG: failed to create directory "\home\aixuser\tex"
*** OCTANE API MSG: FileName::createDirectory() can be called only on absolute file names
<internal> Error(3): script unknown identifier Macro2
deltarod
Postby juanjgon » Mon Dec 10, 2018 11:44 pm
juanjgon Mon Dec 10, 2018 11:44 pm
You can set the Houdini $JOB folder in the top menu File->Set Project option, but you can choose any path on your system.
juanjgon
Return to Houdini
Users browsing this forum: No registered users and 13 guests
Fri Apr 19, 2024 3:50 pm [ UTC ]
