Problems with particle rendering
lehmannudo
Hello Together
I wanted to render particles created with XP4 with Octane 4.0x and noticed that at a certain level the Octane render times exploded, see attached picture.
With Octane version 3.08 I had no rendering problems with particles.
I had to continue the render tests with RedShift, too bad.
Best regards, Udo
Have you tried same scene in 3.08?
lehmannudo
Yes, in 3.08 the scene works!
I'll check it if you post your scene.
Also check Console output and send stats. I marked which numbers are important. See picture.
lehmannudo
Great, enclose the simple szene, you need XP4 as additional tool.
Sand_FluidFX_02_Octane.zip
(59.95 KiB) Downloaded 148 times
lehmannudo
Sorry, I dont know how I get this consolen window
lehmannudo
So, now I've found it, attached is my console result.
V4 engine has a weird behavior with high amount of objects. I'll discuss with Otoy team.
lehmannudo
Thanks for your feedback even if I don't understand what your analysis means and how well you can fix this problem.
lehmannudo wrote:Thanks for your feedback even if I don't understand what your analysis means and how well you can fix this problem.
It's an issue for renderer side. I can't say much more because It's not about my part.
