V4 - LW - Flares and denoising - BUG?
sjonsjine
I was rendering a scene with use of lensflares, so far all fine.
But adding the denoiser removes the flares.
Bug?
By the way when in IPR it works, but rendering via F9 is wrong. It renders with the flares but in the final second it is gone.
Freddy
juanjgon
You are talking about the postprocessing effects, right? Sorry, but I can't reproduce this problem here.
Be aware that the denoising doesn't work if you render by time (or if you abort+continue the rendering) if the "denoise on completion" option is enabled or if the rendering at that point has not reached the min denoiser samples and the max denoiser interval ... not sure if this limitation could be related to your problem.
sjonsjine
I have deleted all objects, NDA, now I have a sort of disk/ coin in front of the daylight sun, also a scattter medium here.
Please check! See attachment! It must be something I forgot or it is a bug. :oops:
Thanks man!
Freddy
Octane-flares-are-gone.zip
(23.1 KiB) Downloaded 211 times
sjonsjine
juanjgon wrote:Hi,
Hi Juanjo, can you please check my attachment in my pre-mail?
Freddy
juanjgon
Ok. Yes, I think that somehow the denoiser can't process the post-processing effects that come from the background daylight. It seems some kind of Octane core issue. I'll ask about it to Octane core devs.
sjonsjine
juanjgon wrote:Ok. Yes, I think that somehow the denoiser can't process the post-processing effects that come from the background daylight. It seems some kind of Octane core issue. I'll ask about it to Octane core devs.
Thanks, I really need this for my project!
Freddy
juanjgon
sjonsjine wrote: Thanks, I really need this for my project!
Freddy
It seems that this problem has been fixed in Octane 4.01, included in the next plugin build that I'll try to release early next week. I'll try to send you an early custom build with this new Octane core as soon as I have it compiled.
3dworks
Freddy
please send it to me as well :-) thank you!!
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
sjonsjine
Freddy
Wow, thanks a lot!!!
Freddy
sjonsjine
Thanks it has been fixed now!
Freddy
Return to “Lightwave 3D”
