Cannot install the octane demo for rhino 6
Micha3D
Same problem here. And the workaround helps to manual load the plugin and set it as renderer.
Other problem:
* fresh opened Rhino and I draw a box and render it - anything is fine
* now open a new empty file - milimeter small objects
* an error popup and all viewports stay black
* Rhino needs to restart
Win7 64 | Dual Xeon E5-2687W | GTX 1080ti 11GB + GTX 780 6GB | Rhino3D
Other problem:
Can you give me the exact set of keystrokes you are using to get this error pls?
Micha3D
I seems to happen if a new file opened, independent which file was opened before. I press the "_New" button and than I choose "Small Objects - Millimeters" and press the open button -> error message.
I cannot reproduce this error, and you have not provided the exact set of keystrokes I requested, so it is difficult to help you on this issue.
Micha3D
Sorry, I don't used any other button than I described, so I don't understand what you are missing. I pressed three buttons per mouse, what should I write more?
I did some more test and found, the Octane UI needs to be opened before. So, maybe this steps help:
* Start Rhino
* open the Octane panel (my panel at the right is open and I need to press the Octane symbol to show the options only)
* open new file per Rhino menu
* -> error
* Start Rhino
* -> error
I am still not getting this error. Perhaps your default rendertarget settings are corrupt? Try deleting C:\Users\[username]\AppData\Local\OctaneRender for Rhinoceros\Defaults\rendertarget.xml.
Also, which version of Rhino and the plugin are you using please?
Micha3D
I deleted the xml file and opened Rhino, switched to Octane and opened a new file. Anything was fine. I opened a new file again and got the error message again. After some click later my computer complete freeze and needs to restart. I restarted and tried again, I get the error message and the black Rhino screen again. No complete freeze now.
I use Rhino 6.10.18311.20531 and Octane 4.00.0.101
My driver is 391.35 because it is the last recommended driver for Octane:
viewtopic.php?f=11&t=68554&p=344376#p344376
I File-New'd 20 times and did not get the error. Do you get it only if Resolution Lock is enabled? Can you post a screenshot of your plugin configuration settings please?
Micha3D
Now I found that my Octane version wasn't updated to ...101, but after geting the update to run, the black screen problem stays, only without error message anymore.
I disabled all non Rhino plugins and restarted, but it doesn't help. I disabled at the film settings the "lock aspect ratio" but it doesn't help. Or did you mean an other setting?
Black screen is usually caused by the resolution being set to 2 x 2. Try changing it.
Return to “Rhinoceros 3D”
