Yeah so its the same issue as all others have with a x299+Skylake-X.coilbook wrote:DinoMuhic wrote:I have (or had) the same problems. While it is true that it mostly is a hardware issue, sometimes its not. For example many have this problem with skylake-X cpus on x299 chipset motherboards and it has to do with voltage not being enough for the CPU so he chokes on to less voltaga. See this thread: viewtopic.php?p=348178#p348178mojave wrote:WHEA stands for Windows Hardware Error Architecture, so this is very likely a HW error, check the Microsoft Answers Community here:
https://answers.microsoft.com/en-us/win ... 77de7a765b
These BSOD are popping up more and more in the last weeks, I also believe that nvidia plays a part in this.
@OP Please install the 416.16 drivers and see if it gets any better. For me it got better with that driver, though I am still investigating.
Which CPU do you use exactly? Is it a skylake intel CPU?
HI I have i9 7900x and ASUS ROG Rampage VI Extreme LGA2066 motherboard
The PC has 3 GPUs plus the forth PCIe is used for netstor turbo box with 4 more GPUs. It would render 20 frames and completely freeze. No errors. Removing netstor box and just having only 3 gpus in the PC helped but it still freezes. Only once it gave me BSOD with whea error all other times complete freeze/lock.
Both PC and netstor have 1600W evga PSUs
Here are my two old posts I am still trying to find a solution
1. viewtopic.php?f=11&t=69237
2. viewtopic.php?f=11&t=69541
Thank you
See here:
https://www.pugetsystems.com/labs/suppo ... LVED-1042/
https://communities.intel.com/message/537268#537268
https://communities.intel.com/message/510365#510365
https://forums.adobe.com/thread/2378916
I am currently in contact with ASUS support.
As you can read in the links above some people have been able to resolve this issue with a BIOS update by ASUS some others by tinkering with voltage settings in the BIOS, which I dont recommend to do unless you are very experienced in the BIOS.
I'm currently trying to convince Asus that this is probably patch-able by their side with a BIOS update.
Please write an email to ASUS support and tell them about this problem. And reference my Ticket number "E1811113483" so they know its the same problem.
It has to do with CPU voltages and the Motherboard not providing the CPU with enough power when it needs it.
Other MB manufactureres (MSI, Gigabyte) were able to fix this with BIOS updates too.
In the meantime, do the following: Look if you have Intel Turbo Boost applications installed on your system, if so disable them and deinstall them.
Then go into your bios and disable the CPU turbo completely.
If this workaround helps you and you dont have any crashes anymore then its proof that its the same problem as all others have.
