Receive shadows doesn't work?
- senorpablo
The receive shadows object property doesn't work in Octane. Is there no way to disable shadows for an object?
- paride4331
- senorpablo
That's cast shadows, not receive shadows.paride4331 wrote:Hi senorpablo,
setting in object properties.
- paride4331
Hi senorpablo,
that feature is not yet availble.
by the way, I did several tests using universal material, around the gamma question we talked about, I would say you're right, it would be better to range 1 as default setting.
- senorpablo
Ok, thanks. I had seem some other posts which referenced receive shadows as if it was a feature, so I wasn't sure if it was broken.paride4331 wrote:Hi senorpablo,
