Receive shadows doesn't work?
senorpablo
The receive shadows object property doesn't work in Octane. Is there no way to disable shadows for an object?
paride4331
Hi senorpablo,
setting in object properties.
senorpablo
paride4331 wrote:Hi senorpablo,
That's cast shadows, not receive shadows.
paride4331
Hi senorpablo,
that feature is not yet availble.
by the way, I did several tests using universal material, around the gamma question we talked about, I would say you're right, it would be better to range 1 as default setting.
senorpablo
Ok, thanks. I had seem some other posts which referenced receive shadows as if it was a feature, so I wasn't sure if it was broken.
Return to “Autodesk 3Ds Max”
