OctaneRender® pre-Beta 2.3 v5 (win/lin/mac) [OBSOLETE]
pixym
- Hotpixel/Firefly removal for the imager, to get rid of fireflies in real-time when tonemapping/rendering with a sensitivity slider. (it's a new slider in the camera tonemapper options)
Maybe you should try this…
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
oguzbir
lixai wrote:still a ton of firefly
can't use this
use the hotpixel removal @ "preview imager" lower the value :)
My Portfolio
radiance
can't use this
you need at least 2000-3000 samples per pixel and then lower the firefly reduction slider slowly until you're happy with the result.
it works really good, just play with it, we did quite a few tests on different scenes. it's %99 perfect.
It's the last slider in the tonemapper node inputs. (hotpixel reduction/removal)
if you have less than 1000 samples/px you will 'blur' the image too much.
it's really only for rendering firefly free finals.
Radiance
lixai
can't use this
Radiance
ok, i'll try, i was thinking that if it is 1, than it's ON
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
oguzbir
Hey radiance,
Thanks for all your efforts once more.
This build is very very good. the UI is flawless..
and ... so much to say..
Anyway thanks for you and your team....
My Portfolio
heydabop
:D :D :D
Win7 Ultimate x64 | AMD Phenom II X6 1090T @ 4.08GHz | EVGA GTX 470 @ 1680MHz [260.99 WHQL] | 8GB RAM
Detailed System Specs (via EVGA Mods Rigs)
http://www.flickr.com/photos/heydabop
Daniel79
No "mtl" in this version?
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
heydabop
Daniel79 wrote:No "mtl" in this version?
No MLT ever.
http://refractivesoftware.com/forum/vie ... =24&t=3475
But their algorithm hasn't been released in this version either. It's a lot of work, and should hopefully be available in 2.3 final.
radiance
No MLT ever.
Yes, the upcoming pre-2.3 v6 will have the new algorithm.
Although, the new firefly removal feature in this release already solves the firefly/hotpixels issue very well (given enough samples/px and finetuning it in real-time when tonemapping).
The only reason why we need the new algorithm now is hidden lightsources and efficient caustic rendering.
Yours,
Radiance
Synthercat
oguzbir wrote:Hey radiance,
I thought that goes without saying but you are right : HUGE THANKS to ALL
(I am just being serious about my bug-hunting eye cause I want to contribute as much as I can)
Here is a good surprise
Check out v4 vs v5 talk about energy loss! - I did it fast (I hope my exposer was not moved on any of them but it might)
v5
v5
v4
v4
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
