How to make fog with a HDR
HHbomb
from the very beginning I don't understand in max all the stuff in octane light (visible, main, ...)
now, I need to make fog effect with an environnement medium.... argh
How can I make some fog with just an HDR for the lightning (not the sunlight) ?
If anybody can help.
SergKlyosov
Hi HHbomb,
Here is a pretty good tutorial about fog https://inlifethrill.com/fog-octanerender-cinema-4d/
In the article author uses Cinema4D plugin, but the same principle goes to Max plugin and SA as well, cause Octane is pretty consistent across all integration
Cheers
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
HHbomb
Thanks SergKlyosov, It is because of this video I wonder how to achieve this in 3dsmax.... But environnement in max is not really the same than in C4d, and as I said I don't really understand all stuff in ocatne daylight UI. :cry:
SergKlyosov
You don't need to use Octane Daylight
Please read the article more carefully, it is straightforward
I've attached screenshot from one of my scenes, so you can have more clear understanding how to apply that knowledge to max plugin
Cheers
HHbomb
@ SergKlyosov,
like this it look very simple... I use octane from version 1 and I don't really look at all the node inputs :oops: Yes, there is a medium input in texture environnement node ! Thanks, I'll try :-)
edit : thank you sooo much
mbetke
I get fog to work but have problem:
I get no falloff in fog. It starts full at camera origin. I tried several ways but had no luck. Usually fog should fade in at lets say 15m and then get more opaque.
PURE3D Visualisierungen
twinsk8
Hi i tried check every parameters finally i did it !
i think volume scattering or absor ramps dont work...
fog
fog
paride4331
here cube fog tutorial:
viewtopic.php?f=27&t=59549&p=304625&hilit=fog#p304633
Return to “Autodesk 3Ds Max”
