Version 4.0-RC7-R4 (obsolete release candidate) 10.11.2018
Ron wrote:
aoktar wrote: Could you send me a few examples. So I can check. Thanks.
I used some of the mix mats from liveDB/Stone. I tried the Asphalt and some others - maybe sending those is not necessary?
It's OK so. I'll try with some presets.
Kalua
Such a great work, Aoktar!
One question: maybe I missed it, but, where is the "Blend - MIX - whatever" shaders conversor of RC7-R2 function?
Cheers,
C4D 2025.1.1 v1.8.4 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
Kalua wrote:Such a great work, Aoktar!
Cheers,
Convert material command. Just select a mix material and call it. Thanks.
thanulee
Thanks for the updates. Will universal material completely replace in the future the standard octane one?
Im asking this, cause im very used to it and i really dislike so far the universal approach haha. thanks
thanulee
Hello, denoiser on, gives me material glitches and render failures. Or at least i think that is whats happening here. cheers
thanulee
One request if possible:
When i use custom luts, is it possible to have a dropdown from each folder with luts that i select? Would fasten up the process by alot! Cheers mate!
Chromfell
Hello. I'm still on RC7, but I doubt this changed in RC7-R2
Running into very bad black artifact on displacement - I have GIFs linked below
GIF 1 - https://imgur.com/a/w0709cT (using complex blend material)
You can see a weird black object. Not a hidden object reflecting, more like ray epsilon problem.
GIF 2 - https://imgur.com/a/Ztc9Vew (using just glossy material with displacement node set to 4k)
Ray episilon does help but also affects the scene as a whole very negatively.
setting displacement to 2K or lower also makes it go away - 4k and 8k lead to this issue.
It also seems to be limited to the absolute 0,0,0 lowest area of displacement map only.
Edit: also affected by U/V amount of tile settings in texture attribute of object in cinema4d, forgot to add. :)
This wasn't here in RC5 using same texture set, something must have changed there. Might be SDK issue, I don't know.
Windows 10 Pro -- RTX 2070 x 3 -- Ryzen 1920X, 32GB -- Blender, Standalone, Cinema4D
FxDesign
Hello Aoktar,
I'm in a situation where the render in the live viewer is different than the picture viewer.
Let me explain
With Xparticles, I'm emitting particles from a shader, then I'm meshing these particles with an Ovdbmesher.
I'm using the vertex color tag in the diffuse to have the vdb colored. In the LV no problem, but in the final render, the Ovbmesher has no color.
Here is a preview of my workflow.
Can you tell if I'm doing something wrong ?
Thank you
FxDesign wrote:Hello Aoktar,
Let me explain
Thank you
Did you changed with render settings? Show me pls if so!
FxDesign
Let me explain
The attachment Sans-titre-1.jpg is no longer available
Thank you
No I did'nt change the render settings of octane, or xparticles.
Here is a screenshot, do you need my scene too ?
Return to “Releases”
