Version 4.0-RC7-R4 (obsolete release candidate) 10.11.2018
abstrax
ndreimi wrote:I'm having an issue where octane is only showing 1.5 gb vram (free+used) on a 980ti with 6gb. No other applications running. I've tried a few different drives with no luck. Results in a CUDA error 700 after awhile.
When you close C4D and try it again do you still see that behaviour? I have noticed similar things before but wasn't able to put my finger on it yet what exactly the problem is. Sometime it goes away after restarting Octane, sometimes I have to reboot. If the problem goes away after restarting Octane or C4D, then the problem is most likely a device memory leak in Octane. If you have to restart your system then the issue is most likely an issue with the CUDA driver.
We fixed a big memory leak in RC6 but there might be more lurking somewhere and any info that helps getting rid of them is appreciated.
VVG
Does Orbx anim pack export "normal" work with XP4 particle export?
tried several times to export cashed particles (small amount for test)
each time the export freeze on different frames
Does ORBX export work with XP4 particles?
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
ndreimi
I tried several restarts along with new CUDA and Nvidia drivers and couldn't figure out a solution. I ended up replacing my 980ti with a 1080ti from another computer and that seemed to solve it for now. One thing I am not sure of however, is the large amount of VRAM being used for a new scene in C4D with a simple cube. Is 600mb typical for that?
VVG wrote:Does Orbx anim pack export "normal" work with XP4 particle export?
Yes!
VVG wrote:dont work?
on/off particles geometry visibility in LV
XP4 0642
it`s classic: repairing one and breaking new.
It doesn't.
VVG
XP4 0642
It doesn't.
then explain to me how the on / off object in Tag works. What am I doing wrong in the video?
XP4 0642
It doesn't.
I mean that's not working. You can continue as you do in video.
tim_grove
When I export a denoised beauty pass and open it in Photoshop it seems to have a slight transparency that isn't present in the original beauty pass. Format is PNG, no alpha and the background is an octane environment with power set to 0.
Is this the expected result?
Screen Shot 2018-10-31 at 11.51.01 AM.png (142.26 KiB) Viewed 4961 times
divasoft
"Added the functionality of saving the any render pass from Live Viewer. You can save a render pass with RMB over pass buttons in Live Viewer"
Ahmet,
VVG
Subdiv Octtag dont export to geometry in animated pack ORBX?
problem/limitation?
upd (explanation)
i try export my geometry with octane subdiv tag to anim pack ORBX.
Open in Standalone - geometry has no subdiv
Return to “Releases”
