OctaneRender™ 4 RC 7
wallace
profbetis wrote:The Universal Material has a strange behavior at low specular roughness values. It has these harmonic ring looking artifacts. These artifacts fade away as roughness approaches 0.002 and up.
I tested the same on the metallic material and no such artifacts exist.
Ray Epsilon has no affect.
The rings shift around when the metallic parameter is adjusted, in my case around the values 0.9 to 1.0
Can you confirm you are using RC7? I can see this artifact in RC6, and I have already resolved this bug.
Double checking in RC7, I am not actually seeing any of these artifacts anymore.
calus
Hi wallace,
Diffuse material with no roughness
Universal Octane BSDF (nice expected similar result )
I didn't notice before but when the universal material have IOR=1 roughness = 1 and no specular, the result of transmission with the "octane" BSDF is very similar to the diffuse material with no roughness. :D
So I get it now, the implmentation make much more sens, but the reason I was confused is because of the weird things happening in this case with the Beckman and GGX bsdf :?: :
Diffuse material
Universal Octane BSDF, result close to diffuse material
universal GGX BSDF, weird result
universal Beckman BSDF, weird result
Pascal ANDRE
wallace
Hi calus,
So basically ggx and beckmann sampling samples a microfacet normal and we then calculate the light direction from it, so they behave vastly different from the octane brdf, which samples a light direction directly.
From what I see, the microfacet models' behavior is consistent across the IOR range so there isn't much I can do specifically for IOR = 1.0 given that this is also used for things like glass.
I will introduce a lambertian BSDF model in future versions so that you won't be limited to a range of IOR dependent transmission models.
Cheers
wallace
coilbook wrote:Can anyone at otoy explain to me when to use AI lights and Ai light update? When I have a lot of lights. I dont see any difference using it or not. Denoiser works the same and noise levels are the same
UPDATE:
I tried a scene with a lot of lights and yes there is a big difference when using AI light but there is a possible bug I posted in max forum when ai lights work in octane viewport and not during rendering viewtopic.php?f=80&t=69152&start=70
As you have stated, AI lights option is used when your scene has complex lighting, what defines complex lighting, it's basically when you have a lot of lights in a large scene that individually affects a small local area in direct light. Sampling them can be difficult when the light emitter has a lot of polygons, since one of these polygons need to be picked. So when these two criteria are met, you definitely want to enable AI light. However, when there is a sufficient number of local lights, it doesn't matter how many polygons are within each light source, AI light still has an effect. As an example, refer to the release post for XB4: viewtopic.php?f=33&t=68283. In the latter case however, if you give enough samples, then the old light sampling algorithm catches up, but this is really scene dependent and sample count dependent.
AI lights update come in to help adaptively update the light selection in direct light sampling, to help learn the scene you have and where the lights are. In the cases where you have a wall completely occluding the light, meaning that the light has no effect in your camera angle/position, AI light update will help understand we don't need to sample this light.
J.C
I can confirm the bug is gone in RC7.
System – Windows 11
enricocerica
Tried to load a render state after created it and got the message :
Failed to load info film from render state file
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
mac3d
Also on Linux...
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
roeland
mac3d wrote:Failed to load info film from render state file
I could reproduce this, it will be fixed. Thanks for the report.
enricocerica
Great, thanks
coilbook
Will we see a procedural noise displacement in this version or next where no mapping is required?
