Tokens question
proundkontra
Thanks a lot aoktar.
If i can add a little thing. It would be super cool to have that little triangle drop down with all the tokens listet as well in the octane save tab.
Is this possible?
nikoeriksson.ch| i7 6x3.5 Ghz | 64GB | 2 x GTX 1080Ti Hybrid , 1x GTX 980Ti Hybrid | Win 10 | C4D R19.068 | Octane Render Plugin C4D v3.08.4
rutv
What test build works with tokens? Can you post a link?
kkoonnsss
Is there a way to use CV tokens with octane so that a render sequence goes into one folder when using the time tokens like $ss $mm $hh.
the standard behavior is so that a sequence goes into one folder but with octane output it makes one folder for each image in the sequence.
kkoonnsss wrote:Is there a way to use CV tokens with octane so that a render sequence goes into one folder when using the time tokens like $ss $mm $hh.
Nope, if you're talking about this! Octane uses the C4D's token system.
bahgoogen
Continuing on from this,
If I use CV Tokens, specifically the Increment 2-digit $cv01
Whether in the file name or folder structure... the 1st few frames will render out correctly, usually 2 frames, then the rest of the render will increment 1 digit and continue on from there.
E.g..
\Filename_v01_0000.png this usually works for the first 2 files. Then it will increment to
\Filename_v02_0002.png for the rest of the render. E.g. most of the files will be V02, not V01.
Any reason why this might be behaving like this?
bahgoogen wrote:Continuing on from this,
E.g..
No idea, conversion is handled by internal functions of C4D. Please share a simple scene to check!
bahgoogen
Thanks aoktar.
Here's a simple scene to demonstrate.
You will see the first 2 files will render into their own folder, and the rest creates a new v02 folder with the files named as v02.
Tokens_Issue_01.zip
Tokens Issue Demo File
(81.4 KiB) Downloaded 181 times
bahgoogen wrote:Thanks aoktar.
This is what I get as output. I cannot see any v.. named subdirs. What do you think?
bahgoogen
It looks like you dont have "CV Tokens" installed?
It's a series of additional tokens you can get from cineversity with a subscription and CV-Toolbox.
https://www.cineversity.com/vidplaylist ... ns_install
token list with CV-Tokens
The $cv01 should turn into an incrementing 2 digit number.
So the first render sequence should be 01, then the second 02 etc.
Your is just printing the token name.
As I said, plugin is using native C4D function to convert token syntax to file names. This 3rd party should not be supported.
