Facet problem
Moderator: JimStar
harshcg
just bought Octane and trying to export a simple scene from Maya2011.
In my knowledgege octane can only understand different objects based on different shaders. So I applied one phone and 2 separate Lambert shader to spheres in maya, and use Export plugin for octane.
Its giving me facets on spheres, even though I applied mesh smooth to one sphere, and also checked smooth on plugin. It does that without smooth on aswell.
But it keeps the smooth for sphere in center, which has lambert1 shader.
Am I doing something wrong here? Or is it just inconsistent.
What other way can i apply new shader to an object, If all the objects have same shader while exporting from maya? Can i isolate objects based on meshes and not shaders?
Any help much appreciated, as this is really frustrating at the very start of Octane usage. Also I will always be using M.aya to Octane pipeline for my projects. That was one big reason I bought Octane.
here I have applied same Lambert1 shader to all the spheres in maya.
this is with first sphere having phong shader.<br />middle sphere having lambert1 shader.<br />and last sphere having lambert2 shader.
bazuka
can u check in octane does some of these spheres have already turned on smoothing?
Maya 2009 x64 & Maya 2011 x64
Windows 7 x64 & Windows XP x64
2x Quad Core Q6600, 8gb, Nvidia Gtx 260 & Gtx 460
harshcg
aah my bad..I'm still learning Octane. Having a smooth option in material for objects is great!
Also one more similar tessellation/facet problem I'm getting while exporting a car model from Maya. Tried turning on 'smooth' on this but it didn't work.
Any other cool tip to fix this artifact?
Thanks bazuka :)
tessellation/facets problem
facets fixed
facets fixed
bazuka
check the faces facing, try to "reset" normals on the car, if u still have probl let me know
nick
maybe also in maya try merging the verts and then jack with the normals.
2x xeon5650 | 3 x titan | Win7 64 | maya2014x64 | mountain mods
harshcg
its still doing it. Tried every option from Maya Normals menu
Average normals
Set to Face
Conform
but its still giving facets not just to the body, but all over the mesh. I NEED to use maya-to-octane plugin, as my renders HAVE to use same cameras from maya. Help pls!
PS: I tried taking same mesh in Keyshot just to see if there was any problem with mesh, it renders fine there :(
face
Maybe you can cut a little piece with the error and upload it here.
So we can test it...
face
http://vimeo.com/user2509578
harshcg
here is one part of the Door, which I tested deleting everything else. It still gives weird facets.
have a go at it. :?
door_test.rar
(2.67 MiB) Downloaded 413 times
face
One zip as obj please? ;)
face
peterd
did you export it as triangulated object (not as quads)?
win7x64|QFx1800|GTX470|Q8200|8GB
Return to “Autodesk Maya”
