16.2.6 Cuda Error
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
aufwind
thanks for the update.
Starting with Version 4, I encounter more and more crashes.
This one happened while detaching a bump texture from a material with displacement while rendering.
I had another crash while changing displacement settings on a heavier scene . No out of vram or cpu ram issue.
Even display driver crashed.
Overall Version 4 is quite heavily blocking the UI of Blender compared to Version 3.07 when rendering.
In Version 16.2.6 Blender randomly flashes a white screen (mostly when starting render, sometimes while rendering).
Reported a while back: 'AI light strength' in kernel settings doesn't exist anymore in Standalone
Win7 | Gigabyte G1.Sniper 3 | I7 3770K | 2x Titan (Kepler) | 1x Titan X (Pascal)
DrawFun
Hi aufwind,
Thanks for your report. It seems to be a cuda failure in engine.
On one hand, I will try to reproduce it and check with engine team. On the other hand, I am merging the fixes in 16.x and going to build a new 15.x release with 3.08.5.
About the 'AI light strength', it seems still there in v4 rc6? Just wondering if I miss something. Thanks.
Cheers,
DrawFun
aufwind
Hi DrawFun,
thanks for looking into it.
In Standalone there isn't a "AI light strength" option anymore , unless I'm overlooking something.
Regarding Cuda Failures, I turned off TDR Warnings, which increased stability quite a bit.
Especially on computational heavy Scenes some of the limits seem to be exceeded.
Are there any Settings to be changed, so that I can enable TDR again?
These should be the default settings set by Octane (except for disabling) right?
Return to “Bug Reports”
