Version 4.0-RC6-R2 (Obsolete release candidate) 19.10.2018
Kalua wrote: EDIT 2: This happenned only once, I restrted Cinema and now it works fine.
Is it fine anymore?
FxDesign
Aoktar,
In this release the passes are not saved/exported at the end of the render.
Here is my simple scene in attachement.
I've tested with other scenes where the rendering of the passes worked in RC5 (and not in RC6)
Do I miss something ?
Thank you
Test_scene.zip
(62.19 KiB) Downloaded 394 times
Kalua
Is it fine anymore?
Its working alright now. I repport if it happens again.
Cheers and thank you for everything.
Octane User since V1 Beta
Kalua
teeshiiddo wrote:
FxDesign wrote:Thank you Aoktar for the material preview :)
How do material preview mode in Live Viewer work?
Also is it possible to enable node sliders or is that feature still to come?
When using the live viwer, click the mouse right b., you will find the option to enable <preview mode>.
I had to recompile and fix due problem on saving passes. Now It's 4.0-RC6-R2. Sorry!
FxDesign wrote:Aoktar,
Thank you
It's fine on R2 anymore.
Kalua
Thanks for all the work, Aoktar.
So I had one more time the preview weirdness I told you before. I attach a two gif examples displaying the behavior. Hope it helps.
Cheers
EDIT: this behavior is not exclusive to the BRDF type cycle, it happens with the edit of any parameter of the shaders.
It's not much exposed because still I need to improve for another gui types as bool,color,etc. But here!
Studio21
Hi ahmet, thx for your work :)
here are a few things i happen to notice:
- Solo mode doest work correctly for specular type materials. the material just goes black in the LV
- Blend sub materials are missing the useful shortcuts in the emission and medium tabs for creating the appropriate shaders (blackbody, scattering etc...those are very handy :)
- Universal material is missing the coating value slider...would be nice to have that
keep up the good work!
Best,
G
Studio21 wrote:Hi ahmet, thx for your work :)
Best,
G
Solo mode with specular that's tricky, I'm not sure how quick to add. But I'll check for other requests.
Btw you can use float texture in coating value atm.
Return to “Releases”
