Txure COmpression
justix
Sorry about this silly question but as the feature is 'suspended' on my plugin ( 3dsmax) and I unfortunately had a GPU fail due to not enough memory :cry: I wanted to try to compress the textures to save some VRam BUT I can't understand how it works? is there a single option to compress what it has been loaded in the scene ( textures ) OR it is an option to enable X single texture?.. can't find it anywhere in the settings. :? Thanks
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
FrankPooleFloating
Yo.. Have you tried the Octane Out-of-Core Textures feature?.. It has only been around since The Middle Ages (of Octane)! ;)
https://www.youtube.com/watch?v=ZvllG9FwuUY
justix
FrankPooleFloating wrote:Yo.. Have you tried the Octane Out-of-Core Textures feature?.. It has only been around since The Middle Ages (of Octane)! ;)
Yes but that is not the same feature is it?
Zay
justix wrote:Sorry about this silly question but as the feature is 'suspended' on my plugin ( 3dsmax) and I unfortunately had a GPU fail due to not enough memory :cry:
In Octane you find it by edit the image settings.
Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
justix
Ok thanks I found it but unsure that it was the Compression setting, I thought there was a Global setting for it not X single texture ( actually that could be useful )
Zay
justix wrote:Ok thanks I found it but unsure that it was the Compression setting, I thought there was a Global setting for it not X single texture ( actually that could be useful )
Yep, just for single textures. Have been asking for a global setting like you as that would have made more sense. Editting 100's of textures is of course not going to happen manually.
FrankPooleFloating
I thought maybe you had not known about Out of Core, since you didn't mention it... So I figured you should start there.
justix
indeed :shock:
justix
FrankPooleFloating wrote:I thought maybe you had not known about Out of Core, since you didn't mention it... So I figured you should start there.
Understood..actually my humble hopinion about the out of core system is that we should give the Out of Core the priority on storing geometry and textures and only on limit reached it should go Vram, I dn't know if that is actually happen already or not
