What you do with cache? Just send it without it or ignore!thanulee wrote:Every RF version i ve used so far has tones of issues. They replicate it at their support and supposedly they fix those. But apparently not. I dont even use GPU on my sims anymore cause i get corrupted files. I might uplaod the infected scene one day for u to check it but its huge atm due to cache size. cheers
Version 3.08.3 (obsolete stable)
Aiight then here is it without the cache.
It should crash with signal on camera when mblur enabled.
U need to cache and then:
If u put signal on camera null (so i can use mblur) it will crash when preparing scene at 70% whenever u try render a range that is not 0-475.
It will also render other objects that are not visible around frame 120-130.
If u find something useful let me know cheers. I dont attach textures etc not needed i guess.
https://www.dropbox.com/s/tnteyc05btzj4 ... L.c4d?dl=0
Please post a sample scene!RyanSilva wrote:Found new issue: Post Processing wont render(completely). Still visible in the Live Viewer.
R20
3.08.3-R2-test1
It appears to only be applying a very small amount of the Post Processing when rendered in Picture Viewer. Check attached image
Oops...
Here it is...
Here it is...
- PostProcessingBug_R20.zip
- (3.17 MiB) Downloaded 366 times
Sometimes an eagle eye does the jobRyanSilva wrote:How have I never ran into that?
Sorry about the fire drill, carry on.
- Silverwing
- Contact:
Hi there everyone.
Since around 3.08 I noticed that the nodes have gotten more inconsistent in size.
As I do a lot of work for clients that later take my shaders and work with them I am concerned about a clean tidy layout. So I usually spend some time with some of the nodes reshaping them to a uniform size.
This is in order to make bigger node trees look tidy and not that messy.
So I wanted to ask if there is any specific reason why the nodes recently lost their shape.
See image attached. How nodes look when dragging them in (left side) and what I would like to see (right side)
Might be that other people have written about it and it has been answered already. In that case please point me toward this thread / communication.
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
