Version 4.0-RC4-R2 (obsolete release candidate) 22.09.201
VVG wrote:
aoktar wrote:
VVG wrote:does not save settings env when restart render or change kernel DL/PT. Always white
R19 and r20
As I wrote It's not a global parameter anymore. It will save the value to scenes and load back. It's done to avoid problems on deadline/network rendering/etc..
explain how to work with it?
how to make you Always be a black environment?
on video is this a normal work?
Wait, there's a problem on this parameter. Btw why don't use an environment object?
skai_tv
Well done!
Thanks a lot aoktar!
Keep it up! :)
OSX 10.13.6 |3770K | 32GB | GTX 1080 |
hyperthalamus11
Hey guys,
I am having issues using the Metal material. It doesn't seem to work in ver4.0 but it works in 3.08.
When you create a new Metal material it creates a diffuse like material and changing any of the parameters doesn't seem to affect it, other than the diffuse channel which does work.
Also, changing the BRDF model to GGX or Beckmann or Ward makes no difference.
Is this a known bug?
R20 screenshot
R20 screenshot
VVG
aoktar wrote: Wait, there's a problem on this parameter. Btw why don't use an environment object?
yep. i UPD my orig post
Perhaps it makes sense to checkbox the global non-global option?
anyway thanks for the work!
Win 10x64, AMD 1950x 16C/32T, RAM 32Gb, RTX 3060x3
Octane-for-C4D(R23.110)2021.x.x, Cycles4D, Centileo. Nvidia 472.47 STUDIO
y81r
hyperthalamus11 wrote:Hey guys,
Set SpecularMap to 1
Please try with updated version!
VVG
aoktar wrote: Please try with updated version!
yes. now works fine!
thanks for fix
please, add drop-down menu for the folder with LUT (in camera tag/ pref)
mesut
aoktar wrote:... Please try with updated version!
i tried the updated version.
dirtnode/opacity/shadow - issue is still present:
viewtopic.php?f=85&t=68833#p346332
win7prof. | i7 4930, 32gb | 2*980ti 6g for renderings | 1*660 for displays
mesut
also still present in this version:
- draw a spline
- add oct-object tag to it and activate "render as hair"
- move around spline-object - > live viewer does not update
- move around a vertex of this spline-object - > live viewer does update
bonus:
- still no emission material for hair rendering
VVG
- draw a spline
confirm (generate Mesh data....)
mesut wrote: bonus:
it limitation
Return to “Releases”
