OctaneRender 3 for Rhino (OBSOLETE)
Refracty
Octane is of course set as default Renderer in Rhino - I have tried with 3.08 and the newest 4 RC but I never see the material previews correctly.
It is very important to have the viewport corresponding to the render view including diffuse, opacity,... and if possible including mix materials.
Can you pls send me a scene where this occurs.
I'm trying v4. I can't see materials previews
Yes, you are right. These appear to not be working. I will investigate.
fabrizio_s
ok thanx
franchais
Hey Paul, I'm having the same trouble installing OctaneRender for Rhino5 3.08.3.97 (64 bit).
It's saying my version Sr12 is not compatible?
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
maray29
Hi Paul,
Found a bug, Rhino Ground Plane stays at 0.0 when you change the height in Octane 4 for Rhino 5.
You need Rhino5, SR14.
I have updated all the TEST installers for the Rhino6 version of the plugin at the top of this thread with:
4.00.0.98 and 3.08.3.98
- Compiled with Octane 3.08.3 and Octane 4.00 RC5
- Fixed multiple issues causing the Rhino rendered view not showing Octane Image maps correctly
- Fixed material thumbnails not rendering with the Octane 4 version of the plugin
fabrizio_s
Hi Paul,
I'm trying v4 (subscription); there are still some little issues with material preview
http://s000.tinyupload.com/index.php?fi ... 6044440404
bye
I could not replicate this problem, however I noticed I posted a debug build of the plugin, so perhaps the installer is not right. Can you pls tell me if this version fixes your problem?
https://render.otoy.com/customerdownloa ... STUDIO.rhi
Refracty
Hello Paul,
I couldn't find the Octane 3.08.3.98 Plugin for Rh6 but tried the Octane 4.00.0.98 for Rh6.
The Material Color is now shown in the viewport. That is great.
The only thing is that the material preview ball looks a bit too milky. It seems the color management is different for that. Can the material ball color correspond 1:1 to the diffuse color box?
The other question I have is the appearance of the color in the viewport. Rhino makes it quite shiny and soft color while octane shows it really strong as setted up.
Is it possible somehow that the material representation within the Rhino viewport comes much closer to the octane material setup?
Thank you
Nando
Return to “Rhinoceros 3D”
