This script is working for me to animate a value. But I want to set the animation to start at a specific time.
For example, for a 720 frame animated piece, I want to animate a visibility at frame 200 and end at 248. With the current script, it starts at the beginning. Is this possible?
thanks,
Dale
Animate value with Lua scripted graph
Hi Dale,
not possible at the moment.
You need to prepare another .ocs with only 48 frames, and add them in compositing.
ciao Beppe
ciao Beppe
- markflorquin
- Contact:
Great Script and how to. Saved me from creating countless manual nodes...
- michalex19
I'm a little late to the party but wanted to check in on this.
Is there not a way to just keyframe in Standalone?
If not, is there a repo of scripts like this one, for instance, if I want to keyframe a transform value, or an rgb value or whatever, this obviously can't be used for those things, so what is the best way to do that?
Thanks in advance!
Thanks in advance!
