Some minor bugs (rhino 6)
fabrizio_s
ave have some issue with octane and rhino 6:
1- I uncheck "Camera visibility" in Geometry (see image). After I save the rhino file. i re-open but Camera visibility is on...so I have to uncheck all the objects that I don't want to see in the render
2- Octane render viewport usually go behind rhino and i'm not able to put Octane render viewport over rhino. So I have to reduce to icon rhino to see the render.
3- (this issue could not be an octane issue but a rhino issue): I open 2 projects (for example project A and project B). I copy an object (with only one material applied) from A, then I paste this object to the B. Sometimes Rhino (or octane) copies not only the material of the object but some other materials.
Do you have the same issues?
Bye
Hi Fabrizio
I have fixed this in version 3.08.3.94 - which I have just posted in the release thread.
I have only ever seen this on very rare occasions - and think it is a Rhino6 bug, but I cannot reproduce it reliably. I have reported it to McNeel https://discourse.mcneel.com/t/form-sho ... o-ui/69114.
If you can setup two .3dm files which demonstrate this issue, I can take a look.
fabrizio_s
Thank you very much Paul. You are super efficient as usual!
For the files...I'l send you in the week
Bye
Fabrizio, can you pls tell me if the Viewport open issue is resolved in this release?
https://render.otoy.com/customerdownloa ... IPTION.rhi
fabrizio_s
Hi Paul
rendering viewport seems ok. Thank you
But now, with OctaneRenderForRhino6_3_08_3_94_SUBSCRIPTION and OctaneRenderForRhino6_3_08_3_95_SUBSCRIPTION, in scenes with many polygons, a cuda warning appear after the voxelizing phase.
Bye
Can you post the full Octane Log (from the Devices tab) report pls?
fabrizio_s
I said this issue appears only with a lot of polygons....I made a mistake. it always happens.
bye
fabrizio_s
Hi Paul,
I sent you a PM with the files for the materials issue.
Bye
Fabrizio
fabrizio_s
Hi Paul,
I have no more the cuda warning...Don't ask me why...I don't know :-D
The problem with materials is still there even copying an object without textures. When I paste it into another scene, it "brings" many other materials.
bye
fabrizio_s
Hi Paul,
please, take a look at this short video I made. The bug of "camera visibility" doesn't seem to be resolved. As you can see if I re-load the file while rhino is running, everything works. But If I close rhino and re-open the file the bug is still there.
Bye
http://s000.tinyupload.com/index.php?fi ... 4358257115
Return to “Rhinoceros 3D”
