Version 3.08.3 (obsolete stable)
Forums: Version 3.08.3 (obsolete stable)
Moderator: aoktar
Re: Version 3.08.3 (latest stable)
Postby tomsvfx » Wed Aug 15, 2018 11:29 am
tomsvfx Wed Aug 15, 2018 11:29 am
Thanks for the fixes!
Will there be new 3.08 builds (except for some plugin fixes for this version) ?
tomsvfx
Postby aoktar » Wed Aug 15, 2018 12:20 pm
aoktar Wed Aug 15, 2018 12:20 pm
tomsvfx wrote:Thanks for the fixes!
Don't know yet! I may prepare new builds If Otoy releases the new sdks.
Postby aoktar » Wed Aug 15, 2018 12:50 pm
aoktar Wed Aug 15, 2018 12:50 pm
andrefry wrote:
aoktar wrote:
andrefry wrote:Offline mode ?
As It's in standalone.
Apologies but is that a yes ?
Been waiting for offline mode to be reintroduced & I'd be super happy if it's happened.
I totally understand but It's not controlled by plugins. This what I'm trying to explain. You should ask to Otoy for this! I have no idea will it come back or not! For my opinion It caused some problems in previous versions.
Postby Kalua » Wed Aug 15, 2018 2:28 pm
Kalua Wed Aug 15, 2018 2:28 pm
Thnaks for all your effort, Aoktar. We all apreciate it!
I 've been having some issues when attaching an image texture to the sheen channel in a blend material... the engine crashes...
I may attach the LOG if you wish so.
Best regards,
C4D 21.207 Octane 2020.1.3 R2 l 3 x 1080 l Windows 10, AMD TR 1900X, x399, 64 GB RAM l NVIDIA SD 442.19
Kalua
Postby aoktar » Wed Aug 15, 2018 2:31 pm
aoktar Wed Aug 15, 2018 2:31 pm
Kalua wrote:Thnaks for all your effort, Aoktar. We all apreciate it!
Best regards,
Please attach what you can! Bugreport, picture, scene, ...
Postby thanulee » Wed Aug 15, 2018 2:44 pm
thanulee Wed Aug 15, 2018 2:44 pm
C4d has an update pending 19.068 or something. Should we update or wait Aoktar?
thanks
thanulee
Postby aoktar » Wed Aug 15, 2018 2:52 pm
aoktar Wed Aug 15, 2018 2:52 pm
thanulee wrote:C4d has an update pending 19.068 or something. Should we update or wait Aoktar?
thanks
I haven't tried yet but updating should not cause any bad-effects for us!
Postby BCres » Thu Aug 16, 2018 11:09 pm
BCres Thu Aug 16, 2018 11:09 pm
This plugin gives me an error inside C4D under network preferences that the remote machine has an invalid plugin ID.
If I replace the plugin with the previous version and boot back into C4D everything works fine. This is all without changing the slave daemon on the remote. I simply leave it running.
The standalone sees the remote machine fine as well. So it's something with this latest version of the plugin.
Here is what I am seeing.
BCres
Postby abstrax » Fri Aug 17, 2018 1:27 am
abstrax Fri Aug 17, 2018 1:27 am
BCres wrote:This plugin gives me an error inside C4D under network preferences that the remote machine has an invalid plugin ID.
The Octane version of the master (in your case the C4D plugin) needs to match exactly the version of your slaves. I.e. if you are using a C4D plugin of version 3.08.3 you have to use net render slaves with version 3.08.3, too, but you are using net render slaves with version 3.08.
abstrax
Postby BCres » Fri Aug 17, 2018 2:40 am
BCres Fri Aug 17, 2018 2:40 am
Thank you, abstrax. I just found the new standalone version. Wasn't aware it existed. It wasn't on the downloads page.
BCres
PreviousNext
Return to Releases
Sat Jul 04, 2020 4:34 am [ UTC ]
