Thanks for the fixes!
Will there be new 3.08 builds (except for some plugin fixes for this version) ?
Version 3.08.3 (obsolete stable)
Don't know yet! I may prepare new builds If Otoy releases the new sdks.tomsvfx wrote:Thanks for the fixes!
I totally understand but It's not controlled by plugins. This what I'm trying to explain. You should ask to Otoy for this! I have no idea will it come back or not! For my opinion It caused some problems in previous versions.andrefry wrote:Apologies but is that a yes ?aoktar wrote:As It's in standalone.andrefry wrote:Offline mode ?
Been waiting for offline mode to be reintroduced & I'd be super happy if it's happened.
Thnaks for all your effort, Aoktar. We all apreciate it!
I 've been having some issues when attaching an image texture to the sheen channel in a blend material... the engine crashes...
I may attach the LOG if you wish so.
Best regards,
Best regards,
C4D 2025.1.1 Octane v1.9 // Octane SA 2026.2, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, NVIDIA SD 595.79
Octane User since V1 Beta
Please attach what you can! Bugreport, picture, scene, ...Kalua wrote:Thnaks for all your effort, Aoktar. We all apreciate it!
Best regards,
C4d has an update pending 19.068 or something. Should we update or wait Aoktar?
thanks
thanks
I haven't tried yet but updating should not cause any bad-effects for us!thanulee wrote:C4d has an update pending 19.068 or something. Should we update or wait Aoktar?
thanks
This plugin gives me an error inside C4D under network preferences that the remote machine has an invalid plugin ID.
If I replace the plugin with the previous version and boot back into C4D everything works fine. This is all without changing the slave daemon on the remote. I simply leave it running.
The standalone sees the remote machine fine as well. So it's something with this latest version of the plugin.
Here is what I am seeing.
The Octane version of the master (in your case the C4D plugin) needs to match exactly the version of your slaves. I.e. if you are using a C4D plugin of version 3.08.3 you have to use net render slaves with version 3.08.3, too, but you are using net render slaves with version 3.08.BCres wrote:This plugin gives me an error inside C4D under network preferences that the remote machine has an invalid plugin ID.
