OctaneRender® for 3ds max® v4.00-XB4 - 6.04 [OBSOLETE]
paride4331
SergKlyosov wrote:
click y wrote:Trying to set some scene in V4, because in V3 its not possible because of the out of core limit.
Its a pretty large scene with about 25 UDIMs and displacements and such
After a while I ran into this error:
Render failure in Viewport Rendering: GPU Failure
this is from the log:
Tried to access attribute via invalid ID A_OUT_OF_CORE_TEX_VRAM_LIMIT
Tried to access attribute via invalid ID A_OUT_OF_CORE_GEO_VRAM_LIMIT
Seems like there still is some out of core limit, or not?
screenshot in attachment, anyone know what this may be?
Facing the same issue. I opened an old scene which run on V3 fine and tried to render it with this release.
In V4 I was prompted that system ran out of memory, so I tried to use Out of Core feature and received same GPU failure and octane log errors
Cause of that some of my textures are rendering completely black
Hi SergKlyosov,
thanks, maybe something like issa user using SA.
I will add your post to developers report.
paride4331
coilbook wrote:
paride4331 wrote:
coilbook wrote:why cannot i open even viewport with octane 4? is it a bug I just have one box and one light
My octane viewport works using your file.
Hi Paride, where is "save the denoised beauty instead of the main beauty pass" located?
It seems that XB4 opens way slower than XB3 like 5 times slower
Hi coilbook,
Render elements > Denoiser pass: Denoised.. *
SergKlyosov
paride4331 wrote: Hi SergKlyosov,
Hi Paride, thank you for the reply
I don't know what you meant as a "issa", I've exported this scene to Octane 4 RC1 - and it is rendering fine, using 2.5GB out of core memory
So I think this issue is related to 3Ds Max plugin
Also in SA we have feature called AI Scene, which helps to achieve more smoother viewport performance, if I'm correct
Where this feature is located inside 3ds max? In Kernel and Imager tabs I can find only AI lights, not AI scene. Is it turned on by default or it is not integrated yet?
Cheers
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
paride4331
Hi SergKlyosov,
I'm sorry.. Issa is a forum user reported SA out-of-core creshes issue.
AI Scene is Brigade tech, it is an essential SDK part. Maybe developers could add Ai Scene feedback during scene evaluation
coilbook
Thanks[/quote]
Hi coilbook,
Paride[/quote]
But when i render it now saves 2 files one is denoised another one is not denoised. Anyway to have a checkbox save denosied as a final beauty image ?
paride4331
coilbook wrote:Thanks
Hi coilbook,
Paride[/quote]
But when i render it now saves 2 files one is denoised another one is not denoised. Anyway to have a checkbox save denosied as a final beauty image ?[/quote]
Hi coilbook,
I don't know if "save the denised beauty instead of.." as in batch render; I'll ask to developers.
coilbook
Hi coilbook,
Hi coilbook,
Paride[/quote]
thanks Would be nice to add a checkbox somewhere next to the denoiser saying save final image as denosied beauty and not a regular beauty. Most people will want final image as denoised beauty and not just beauty
ramone163
Denoiser on large images crash Standalone and 3ds Max plugin.
Scene is only 1.5 Gb of VRAM. So how much denoiser need to render 5000x5000 pixel?
Please fix it.
980 for monitor
980 for monitor
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
coilbook
Hi is there anyway to create iridescent clouds ? I mean the rainbow color effect. Not sure where to begin Thank you
justix
I have problems in using cameras, it seems that now all cameras values look like instancing in the the scene.. anyone? :( it is really annoying as I have 3 cameras with different FOV .. but any change made on one change change the same value on the other ones ????? + I just ha a GPU failure due to NOT ENOUGH MEMORY FOR DENOISE while having 4 Gigabyte free memory left? ( max 2018 )
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
Return to “Releases”
