OctaneRender™ V4 XB4
Notiusweb
I have to ask for this!
In Universal Material - would it be possible to put...in addition to Power, and Gamma...an image Saturation pin?
This would really take things to the next level to have a full slate of editing abilities like some other PBR engines have, in one material.
I appreciate this consideration!
Mobo: 1 Titan RTX, 1 Titan Xp
Plugs: Enterprise
wallace
Notiusweb wrote:I have to ask for this!
This is more of a general image operation you want to do, it's not strictly relevant to the universal material. You can actually achieve this via OSL texture, for example:
shader OslTexture(
    color inputColor = 0,
    float saturation = 0 [[float min = 0.0, float max = 1.0]],
    output color c = 0)
    color hsl = transformc("rgb", "hsl", inputColor);
    hsl[1] = hsl[1] * saturation;
    c = transformc("hsl", "rgb", hsl);
saturation OSL texture
Notiusweb
shader OslTexture(
    output color c = 0)
Hi, thank you. Do you know reason I might be experiencing this error:
Also, is it possible to still have Gamma and Power with Saturation, or can OSL only do Saturation without Gamma and Power?
:oops:
THX!
Plugs: Enterprise
funk
Could you guys share that AI light example from the first post?
paride4331
coilbook wrote:should I use denoise on completion or denoise every so many seconds for animation? is there much difference? Thanks
Hi coilbook,
once you verified correct denoise setting in your scene, I personally would recommend for denoise on completion.
you will save time for each frame you render.
coilbook
Hi coilbook,
Thank you! What about AI lights? Do I need to enable ai lights and ai update? Or only when I have night scenes with hundreds of lights? There is not a lot of info about it
wallace
Notiusweb wrote: Hi, thank you. Do you know reason I might be experiencing this error:
:oops:
THX!
My bad, it seems like it's a feature available post-XB4. The point of this is you can connect an image texture as an input to this osl texture node, so you don't actually lose gamma and power for your image texture.
I'd like to say you should use this OSL texture sparingly as it involves transforming between color space twice, so only use it when you absolutely need to change the saturation.
To use this texture node, please head over and download our latest V4 RC1: viewtopic.php?f=33&t=68491
wallace
funk wrote:Could you guys share that AI light example from the first post?
Here is an example of AI light test scene. Please note that we have since found and fixed a few bugs of AI light and also implemented the AI light update again after XB4, so I would recommend you download the latest build to use this feature.
And here is RC1: viewtopic.php?f=33&t=68491
coilbook wrote: Thank you! What about AI lights? Do I need to enable ai lights and ai update? Or only when I have night scenes with hundreds of lights? There is not a lot of info about it
AI light is a completely separate feature from denoiser. It works better with increasing number of lights, it's basically a smarter light sampling algorithm, I'd advise you to use it when your scene has some complex lighting with many lights or walls, plus when you see your direct light passes with diffuse/reflection struggling to find sample lights in the scene.
AI light test.orbx
Ai light test scene
(152.84 KiB) Downloaded 318 times
funk
Thanks Wallace
Notiusweb
:oops:
THX!
:P YES! this is great!
THX!!!!!
Plugs: Enterprise
