trouble with version octane for poser 3.08.0.87
Forums: trouble with version octane for poser 3.08.0.87
Forum for discussing Redspec SSS.
Moderator: TRRazor
RedSpec SSS and TGX © RedSpec SSS
http://redspec-sss.com
Postby goorz » Sun May 06, 2018 1:06 pm
goorz Sun May 06, 2018 1:06 pm
hey there
I downloaded the latest version of the octane poser 3.08.0.87 and when I apply sss skin shader for g2 I got this
https://sta.sh/01hhqgfob69i
with the older version I got the good one
https://sta.sh/07occsr3rgq
can someone help ????
goorz
Re: trouble with version octane for poser 3.08.0.87
Postby TRRazor » Wed May 09, 2018 2:25 pm
TRRazor Wed May 09, 2018 2:25 pm
Yeah, I see what the problem is.
Obviously, the normal map node channel behavior was changed with the most recent update, and now Octane shows this weird surface, when there is s Normal node with a value of "0".
A quick fix for now would be to set every single Normal channel node to "1" instead of "0", that fixes the problem.
We'll release an update to fix this issue in the near future.
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
REALISTIC HUMAN SKIN SHADING - REDEFINED
RedSpec TGX Hair for Poser / DAZ Studio OctaneRender - OUT NOW visit http://redspec-sss.com/
TRRazor
Postby goorz » Wed May 09, 2018 7:44 pm
goorz Wed May 09, 2018 7:44 pm
ah ok good to hear and thank you for your help ,I will try that later on ;)
goorz
Postby TRRazor » Fri Jul 06, 2018 4:56 am
TRRazor Fri Jul 06, 2018 4:56 am
There is an Otoy-sided fix incoming for this - please refer to our journal entry here:
EDIT: The fix is now available with version 3.08.2.88 of the OctaneRender for Poser plug-in.
Please make sure you'll have it installed from over here: viewtopic.php?f=45&t=56137
TRRazor
Postby goorz » Thu Aug 02, 2018 1:59 pm
goorz Thu Aug 02, 2018 1:59 pm
have downloaded and tried the latest versions but same hit again :o version 3.08.2.88 is same as the previous
goorz
Postby TRRazor » Thu Aug 09, 2018 12:34 pm
TRRazor Thu Aug 09, 2018 12:34 pm
We've tested the most recent version of the OctaneRender for Poser plug-in against the Normal-mapping issue and found it was fixed, so it is probably something on your end.
Could you please let me know via PM which version of the plug-in you are using and attach a screenshot of the unfold material tree?
Thanks and regards
Noel
TRRazor
Postby goorz » Thu Aug 09, 2018 5:59 pm
goorz Thu Aug 09, 2018 5:59 pm
thank Noel for your response but it's solved was using the wrong version. :oops:
goorz
Return to Redspec SSS
Tue Jul 07, 2020 4:59 pm [ UTC ]
