Rendering many layers into a single exr?
- Norman_Stansfield
As in the subject. Is this possible in Octane for 3dsmax? Render Layer (and its ID) button hides all other layers than the active ID. But do I have to render separate tiff sequences for each layer (f.e. 4 x 6300 frames) or is there a way to write all layers into one exr frame and switch them on/off in compositing software? Similar like psd file in photoshop...
- paride4331
- SergKlyosov
Hi Paride,
I've already asked the same question as a topic caster
But, how I can use workflow which you wrote above - using Octane Viewport?
It is saving all render passes separately, instead of one solid EXR with all layers inside
I've recorded a video to show the issue
Cheers
https://www.youtube.com/watch?v=IvAzTmu1UJo
Cheers
Win 10 64 | RTX 3090 | i9 9980XE | 64GB RAM
@Paride,
I think Norman was asking specifically about the Render Layers, not really the passes. He wants to render Render Layer 1 and Render Layer 2 at the same time, but they'd go into different layers once in photoshop - all with an EXR. So it makes masking easier. This is somewhat related to my post (unanswered) about Render Layers and that they show through to the background on their edges.
- Norman_Stansfield
1. Thanks paride, it's not exactly what i ask aboutparide4331 wrote:Hi Norman_Stansfield,
I hope it helps.
2. Separately of that question there is another one: How to use Render Layer ID/object ID element, by the way? Masking by color in nuke or after effects in post isn't accurate. Especially if renderer sets the color ID of different objects very similar. How do you guys work with these very basic features in post-production
Best,
nl
- richardyarlett
I just posted on this 2 mins ago. It is NOT POSSIBLE to do all in one go around. They recommend use LAYER ID and OBJECT ID to render layer passes out separately, but you as and I both know that is super slow and dumb. We want 8 objects, all rendered out in one frame, but with 8 separate sub layers of each beauty pass PER OBJECT. I used to use PSD MANAGER to do this with VRAY. But it does not currently work with OCTANE.
In 2018.1 they are moving over to the new CRYPTOMATTE technology which will totally rewrite the rules for layers and render elements etc and you should be able to extract whatever you want. But until then, there seems to be now why to do this in a single pass.
The best workflow right now is just render a normal full beauty pass and then use the object or material id pass to pull them out onto separate layers in After Effects using the "linear color key" effect.
Cyptomatte is the best method for getting out mattes to control your compositing. If you need to render out a specific object(s) with all the raytracing effects from your surrounding, but keep your surrounding matte black, activate Render Layer Setup.
Details on how to use it can be found in the manual here -
https://docs.otoy.com/3DSMaxH/3DSMaxPlu ... Layers.htm
