Version 3.08.2-R3 (obsolete stable)
slepy8
When I was rendering last animation I found an issue.
I had instance objects with "Render instance" enabled.
When I was rendering a sequence, some or all of those instances where not rendered in some frames. It happened randomly.
What's more interesting is: when I stopped rendering. And started from the frame where those instances where not visible, they were now present. But after few frames they were dissapearing again.
Disabling "Render instance" helped. All frames where rendered perfectly.
slepy8 wrote:When I was rendering last animation I found an issue.
Please send me your scene!
stefano-dear wrote:Hi,
in this release the function "remove duplicated materials" doesn't work? :roll:
best regards
Stefano
I think so, checking it! Is it too urgent for you? I have to work for latest V4 build now.
Ron
best regards
Stefano
Not urgent for me :-)
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
stefano-dear
best regards
Stefano
Not urgent, I prefer the V4 release :D
Thanks Aoktar
thanulee
Hi vertex maps, do not work in mix material but work in mix texture. Is that known? thanks
edit: sorry i found out that via baking texture and uv channel 2, it works but its quite heavy. Thoughts?
thanulee wrote:Hi vertex maps, do not work in mix material but work in mix texture. Is that known? thanks
It's working as i can see
thanulee
Sorry didnt clarify, im playing with RealFlow plugin and its maps. Also since all my machines are rendering atm at office, i have demo 3.08 at home and playing with it. Have u tested realflow vertex maps? thanks
slepy8
aoktar wrote: Please send me your scene!
Sorry mate. After I started resaving this scene for you the issue was gone. I'll report if I encounter it once again.
Cheers!
thanulee
Hi, this happens in 3.07 as well. If i use random color on a cloner, and i start my render while my timeline is not at 0, the colors are different every time.
This also happens if i stop a render queue and resume it. Is that a known issue? ty
Return to “Releases”
