Hi all,
Here is new plugin built over OctaneRender 3.08.2 SDK . Enjoy it and don't hesitate to give any feedbacks!
WINDOWS REGULAR BUILD
https://render.otoy.com/customerdownloa ... R3-win.rar
WINDOWS SUBSCRIPTION(Studio) BUILD
OSX REGULAR BUILD
https://render.otoy.com/customerdownloa ... Macosx.zip
OSX SUBSCRIPTION(Studio) BUILD
OctaneRender™ Standalone 3.08.2
viewtopic.php?f=24&t=68091
For an overview of all new features of 3.08, please read the new features thread.
Changes of Version 3.08.2-R3
-Fix: Missing activation window on clean install of plugin.
-Fix: "Remove duplicated material" command.
Changes of Version 3.08.2-R2.1
- Fix: Workflow performance penalty with using a relative path on ImageTextures when you have a long list of search paths.
- Fix: Loosing node with blend material when you do copy/paste to another scenes or similar actions.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053). Otherwise the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by firewall and any antivirus software.
-Updated Nvidia drivers(most recents like 39x.x) with Cuda 9.1 - change driver versions if you have much trouble with current driver
MANUALS:
Offline HTML: https://render.otoy.com/plugindownloads ... manual.zip (extract to c4doctane directory)
Online manual: https://docs.otoy.com/Cinema4DH/C4DPluginManual.htm
Partial help for Instance Color and Instance Range nodes:
Instance Color: https://drive.google.com/open?id=1uMyw4 ... mvoaHyYBVb
Instance Range: https://drive.google.com/open?id=1FF1ad ... eY8XjD10w1
V3 SAMPLE SCENES SET(make a request if you need any spesific sample)
https://render.otoy.com/plugindownloads ... scenes.rar
See this topic for some partial samples: viewtopic.php?f=85&t=53989
CINEMA 4D TUTORIALS SECTION: viewforum.php?f=87
CHANGE LOG: https://docs.otoy.com/#60Change%20log
Installation
First remove all octane related stuff from plugins and main folder of Cinema4D.
Also download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R18.0, keep only "c4dOctane-r18.cdl64" and delete c4dOctane-r17.cdl64, c4dOctane-r16.cdl64, c4dOctane-r15.cdl64, etc..
Cinema 4D Release 13: c4dOctane-r13.cdl64
Cinema 4D Release 14: c4dOctane-r14.cdl64
Cinema 4D Release 15: c4dOctane-r15.cdl64 or c4doctane_R15_demo.dylib
Cinema 4D Release 16: c4dOctane-r16.cdl64 or c4doctane_R16_demo.dylib
Cinema 4D Release 17: c4dOctane-r17.cdl64 or c4doctane_R17_demo.dylib
Cinema 4D Release 18: c4dOctane-r18.cdl64 or c4doctane_R18_demo.dylib
Cinema 4D Release 19: c4dOctane-r19.cdl64 or c4doctane_R19_demo.dylib
Viewport rendering mode
https://vimeo.com/265747658
https://vimeo.com/265294205
Version 3.08.2-R3 (obsolete stable)
- eyeonestudio
- Contact:
Thanks for the quick update. I will test soon.
There are additional requests.
Currently the Forester - Multi Cloner works well.
However, Display Points must be Off.
If turn off Display Points, the viewport will be very slow.
This is a major hindrance to work.
If you can get information from the Forester developer
Can I render with Display Points on?
CINEMA 4D R2025
Win11 / AMD 7995WX, 3995WX, 3990X, Intel 10980XE / 256Gb RAM / RTX4090, RTX3090 / 100GbE, 40GbE, 10GbE
It will be supported on forester 2.0.eyeonestudio wrote: If you can get information from the Forester developer
Thanks for the release Ahmet! Keep up the good work!
Thanks for a super quick release Ahmet!
I'm happy to report that ( as I suspected ) 3.08.2 SDK fixed this material preview crash with
Cheers
Milan
raytype()
. Also, Marcus confirmed that the same bug fix was in the V4 XB3. That explains why V4 was working fine for me.Cheers
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
Hi Milan,milanm wrote:Thanks for a super quick release Ahmet!
I'm happy to report that ( as I suspected ) 3.08.2 SDK fixed this material preview crash withraytype()
Cheers
Milan
Good to hear! It was a core problem as we found! Please share if you find any problems about OSL, many thanks!
- LOVEXMEDIA
Will there be a patch that implements more GPU's to be used for the subscription users before the full Release of V4?
I'm not sure if it would be a simple flip of a switch for you all or if it's something that will require more testing with users to fully maximize the new capabilities.
I am excited either way and I am scooping up a few 1080ti's for the V4 drop when it drops!
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
Just a reminder again about vdb's viewport preview. They seem so show 1/4 of the cloud shape, no matter what vdb i use ( i posted that in 3.08 2 i think again). cheers
I had to do a release, so I couldn't finished to fix it.thanulee wrote:Just a reminder again about vdb's viewport preview. They seem so show 1/4 of the cloud shape, no matter what vdb i use ( i posted that in 3.08 2 i think again). cheers
No worries, thanks.
