Octane 3 and 2nd GPU Not Working ??? Help
3dcgmodeler
I have 2 video cards a Titan and GTX-1080
And the Titan has no problem, but when I try to enable the GTX-1080 it does nothing (the 1080) then I disable the GTX-1080 it goes back to processing the image.
It use to work with earlier versions???
From the Newtek Forum.
I am running 3.08.1.0 ... (Licensed version) Lightwave 2015.3 (64bit)
And I have a Titan and a 1080. I enable the 1080 which is GPU0, I get an error.
It works fine with the Titan, just cant use both at same time. interesting it is
Octane recognizes the 1080 and knows it there??
Yes the video drivers are version 398.11
Mike
ASUSTeK COMPUTER INC. ROG STRIX TRX40-E GAMING Rev 1.xx
1Ryzen Threadripper 3970X 32-Core - 3900 MHz (32 cores, 64 threads)
131072 MB DDR4 DIMM 2133 MHz (8 of 8 slots)
juanjgon
What error do you get? Perhaps the problem is that you don't have this GPU enabled for tonemapping, and at least one must enabled to see the rendering in progress.
Do you know if the Octane 3.08 Standalone has the same problem?
3dcgmodeler
Well I did what you said and checked everything
it was working with both cards?
hmmm
Still cant seem to get it to work with both cards
Mike
Octane.log
(30.19 KiB) Downloaded 235 times
3dcgmodeler
Ok I loaded the 4.00.0.8 version plugin..
everything works except when I try to use the GTX-1080 card..
works fine with the Titan - Black ???
Image 8 is the error I get " RENDER FAILURE: the render can't be completed. Enable and check the log file for more details."
I looked at the log file and well did not see any thing??
Mike
3dcgmodeler
Well I can use Lightwave 2015.3 32 bit and octane 2.24.0.1
and everything works great... both video cards are rendering just fine
hmmmmm
LightwaveGuru
3dcgmodeler wrote:Ok I loaded the 4.00.0.8 version plugin..
Mike
mike
take it off...
hope it helps...
snip lwguru
http://www.neotek.laboratories.de or http://www.youtube.com/c/Lightwaveguru or http://www.facebook.com/safarifx 4x Titan X 12 GB watercooled / 6x 2080 ti air cooled / 2x 980 ti watercooled
juanjgon
It is a weird issue. Do you have these cards linked in SLI mode or something like that?
3dcgmodeler
No SLI
Yes the use all for F9/F10 is "Off"
3dcgmodeler
I am back to using the 3.08.1.0 version the 4.0 don't work either??
juanjgon
So in short, you say that none Octane 3.08 or Octane 4.00 work with your two GPUs enabled, right? Well, it is really a weird issue that must be system related for sure, because I don't have other reports about problems like that using multiple GPUs.
Do you know if Octane Standalone has the same problem while trying to render using the two GPUs?
Return to “Lightwave 3D”
