Version 3.08.1-R4 (obsolete stable)
eyeonestudio
aoktar wrote:
carterner wrote: Hello, just tested the new 3.08.1-R2 version. Using Multi Cloner will still stop C4D. After testing 3.07R2, there is no problem at all. Can I recover to 3.07R2?
Which version of forester? Could you please share a scene with me?
Here is Bug Report.... Forester 1.28 + Octane 3.08.1-R2 :(
Forester 1.28_bugreports.zip
(698.51 KiB) Downloaded 341 times
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
Could you try with this new build?
https://render.otoy.com/customerdownloa ... R2-win.rar
eyeonestudio
It's Working GOOOOD...... :D :D
Thanks....
eyeonestudio
Wrong Reports - GPU Usage, Temperature....
I have no problems using Octane, but I report a bug.
This problem has persisted for a long time.
System Configuration
ASRock Fatal1ty X399 / Ryzen 1950x / 64Gb Ram / Titan Xp x 2 / 1080 Ti x 1 / Win 10
I am using Titan Xp in TCC mode(Like Tesla).
The problem occurs when use "TCC" Mode.
Take a look at the picture.
Second Titan Xp Usage -1%, Temperature -1
carterner
I'm using version 1.1.0. I don't think it is necessary to provide the scenario. I just need to create a new Multi Cloner and it will just die. Every time I do this.
Please re-download files. I've replaced with a fixed version.
carterner
aoktar wrote: Please re-download files. I've replaced with a fixed version.
OK,so perfect!Your update is too timely~ thank you vray much.
thanulee
Hi, it says on the release notes "support for matrices of multicloner". That is only for PV i guess? ty
thanulee
Two more things that need fixing (i guess are already known from other users feedback) :
a) glossy icon is same as specular icon
b) vdbs dont show correct in viewport (see image below)
thanulee wrote:Hi, it says on the release notes "support for matrices of multicloner". That is only for PV i guess? ty
Temporarily i removed this support due crashes.
Return to “Releases”
