Sketchup plugins do not save settings
Forums: Sketchup plugins do not save settings
Postby Kenji_Wong » Fri Jun 08, 2018 9:07 am
Kenji_Wong Fri Jun 08, 2018 9:07 am
I've updated the plugins to the latest version 3.08.1 but it still give me the same problem.
I created few scene tabs as instructed and assigned materials to objects. When I reopen my file, some of the materials were saved but some were not.
Some object even lost its 'material out' link. I've to reassign the materials to the objects several times again and again to the same scene of job.
Hope you can help to solve this problem.
Kenji
Kenji_Wong
Re: Sketchup plugins do not save settings
Postby _qmvc3WkfIhgYS » Fri Jun 08, 2018 12:50 pm
_qmvc3WkfIhgYS Fri Jun 08, 2018 12:50 pm
The latest stable version in my opinion is 3.04.5 https://render.otoy.com/forum/viewtopic.php?f=24&t=57660
If you still find the plugin unstable, you could try exporting your scene to *.ocs/*.orbx and work in standalone (the renderwindow has to be active for the export option to work).
Personally I do not like exporting since all the settings get exported time and time again. For standalone better to have a setup and just update a single OBJ file, but this doesnt work with sketchup scince the scene splits up.
You might find all this complicated and the plugin unfinished, if so, ask for a refund. (I keep using an older version because my company have not taken the descision to switch to vray yet)
_qmvc3WkfIhgYS
Postby bepeg4d » Fri Jun 08, 2018 1:07 pm
bepeg4d Fri Jun 08, 2018 1:07 pm
Hi Kenji,
please, share a scene via PM with me that is giving you issues.
We are unable to reproduce the issue here, and the faster why to solve it, is to have a scene that shows the issue for sure.
ciao Beppe
Postby MicroCADDAus » Wed Jun 13, 2018 1:08 am
MicroCADDAus Wed Jun 13, 2018 1:08 am
Hi there,
I have the same problem.
All material settings modified in Octane will disappear once I close the window of Octane render in Sketchup. I can't export the scene either.
Is there any way to save the material settings?
MicroCADDAus
Postby Kenji_Wong » Wed Jun 20, 2018 3:34 am
Kenji_Wong Wed Jun 20, 2018 3:34 am
Hi, I've attached a sample below. I've to redo the material assigning again and again.
But then, I've just realised it was when I modified or make changes to the sketchup file, the settings in octane will reset to default.
[img]
[/img]
[img]
[/img]
Kenji_Wong
Postby prehabitat » Wed Jun 20, 2018 9:26 am
prehabitat Wed Jun 20, 2018 9:26 am
Can you share the file with the dev’s via PM?
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
prehabitat
Postby johlanga » Fri Jun 22, 2018 12:08 am
johlanga Fri Jun 22, 2018 12:08 am
This has been reported ages ago....
For me it's somehow better when I only use "Colors-Named" in SU.
You can try that...
Win7 Sp2____2xGTX1060 [email protected]____Su17.2.2555 and Su18.0.16975____SketchUp Plugin 4.00.0.17____4.00.RC7 Standalone
johlanga
Postby teeshiiddo » Wed Aug 08, 2018 10:55 am
teeshiiddo Wed Aug 08, 2018 10:55 am
I'm still having this issue with 3.08.1 and 4.00.04
When adjusting an auto converted texture in the octane interface by adding a texture emission, then close and reopen the octane window and the material adjustments are lost.
Asus X99 10G WS | Windows 10.0 | 6x GTX 1080 Ti + 2x 2080Ti | i7-6850K CPU @ 3.60GHz | 32GB RAM
teeshiiddo
Postby azen » Thu Aug 09, 2018 6:13 am
azen Thu Aug 09, 2018 6:13 am
teeshiiddo wrote:I'm still having this issue with 3.08.1 and 4.00.04
Thank you for feedback. Further updates are pending soon, so I will explore the status of this particular issue with the rest of the team.
Cheers,
Azen
azen
Postby teeshiiddo » Thu Aug 09, 2018 9:55 am
teeshiiddo Thu Aug 09, 2018 9:55 am
Cheers,
Azen
I found a workaround. I can DM an example scene if helpful.
teeshiiddo
Next
Return to SketchUp
Sat Jan 23, 2021 5:52 pm [ UTC ]
