Version 4 - XB2.1 (Test2)
carterner
Hello there,
       I don't know whether or not you have noticed that the Forester plug-in can be used normally without mentioning support before 3.08. Since it was said to support it, it will always be buggy, including the v4 version. In the 3.072r2 version can be used normally, especially multicloner, as long as nothing is used to operate, oc will crash, unable to render. If you need to upload a comparison chart, I will upload it again. The system is win10, the driver is 391.35.
    C4DR19.53
Good lucky
carterner wrote:Hello there,
    C4DR19.53
Good lucky
Hard to understand you report, I've modified some codes for direct access to multicloner. Please post a scene for testing.
carterner
_BugReport.zip
(26.21 KiB) Downloaded 292 times
C4DR19.53
Good lucky
thanks for you
forster_test.zip
(142.98 KiB) Downloaded 318 times
mpazera
We have exactly the same problem with 3.08.1-R1 and forester.
We had to revert back to 3.08, and now forester works.
win10
c4d r19.53
Nvidia driver 398.11
2x Titan x
mpazera wrote:We have exactly the same problem with 3.08.1-R1 and forester.
win10
c4d r19.53
2x Titan x
I'm estimating what's the problem. I'll check it.
Return to “Releases”
