Do you know if the Octane 4.00 XB3 works on your system? Nothing has changed in the compiler from the Octane 3.08 plugin builds ...AndyM1969 wrote:Using LW2018.0.4 and I'm sorry mate, I just can't get it to install. Is there a newer C++ package I can install?
viewtopic.php?f=33&t=67790
Also, remember that if you had a previous version installed, you must remove the Octane master plugin from the master plugins options panel, before adding the new plugin build.
