denoise phase crashes 3dsmax and display
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
umut_sert
When it comes to the denoising phase for the new 3dsmax 6.01 plugin
the display goes blank and ı have to restart the computer. I have two 1080tis and latest drivers installed . I use both cards for gpu rendering and one of the two for denoising and tonemapping. I have no extra cards for display.
umut_sert
windows 10 64 bit
398.11 display driver
3dsmax 2018
octane render 4 xb3
plugin 3dsmax - 6.01
ram 16gb
2 1080tis msi
paride4331
Hi umut_sert,
could you make a test setting your hadware as follows:
1_ 1080Ti:
active > yes
Priority > yes
Tone > yes
Denoise > no
2_ 1080Ti:
active > no
Priority > no
Tone > no
Denoise > yes
connect monitor/s here
Have you still crash?
umut_sert
can it be a power issue, or during denoising does the cards consume more power than usual rendering. Because when it starts denoising, it restarts the system or either display driver is reset. I do not have the same problem with other optix using renderers.
paride4331
Hi umut_sert,
what about your Power supply, how many watts?
umut_sert
this was my office computer. And at home ı use two titan x maxwells with denoiser and it works like a charm.
paride4331
Hi umut_sert,
if you did my test and the problem persists it could depend on power supply, check it.
umut_sert
(ı did the test for both cards and both of them worked as single denoisers.They worked as you have requested
umut_sert
Hello Paride, what is your theory about my work computer crashing during the denoiser phase. Last saturday with watery mouth ıI tried to render a scene which occupies 8gb of vram on 2560x1440 res. ıt crashed, later I learned from our ıt guy that power supply is shut and locked .My computer seems to have a power supply of 650 watts with two 1080tis attached. ıt has a 8 core amd fx processor with 32 gb of vram.It has an ssd and two normal harddrives. IIt may also be a heat problem, but ı think if it would be about system temp than it would randomly reset instead of the sarting of the denoiser pahse . if we can find a solution I would be grateful. Thanks in advance...
paride4331
Hi mut_sert,
I suppose your issue depend on PSU:
2 x 1080TI > 500 watt
1 x cpu > +/- 125watt
crashes and reboots are possible when wattage peaks.
before purchasing a new PSU, try to removing 1 x 1080TI and test it.
paride
Return to “Bug Reports”
