Rhino Plug-in 1.022r01.01
SamPage
Attached is an update which attempts to prevent Octane from crashing on open. It adds one additional command, OctaneClearOptions. Please run this command on the first run of the plug-in, it will clear out the any options which older version of the plug-in may have written.
Sam
RenderOctane.zip
(131.86 KiB) Downloaded 537 times
Win 7 64bit | 2x GTX 285 | i7 920 | ASUS P6T Deluxe | 12GB
8Eggar8
Getting close to setting up that 'paypal / donations' option. ;)
Doing Great work Sam!
MSI NF980-G65 AM3 NVIDIA nForce 980a AMD Motherboard - AMD Athlon II X4 620 (Overclocked to 3.2ghz)
(2)GTX460's, (1)BFG gtx260, OCZ 60GB SSD, KINGWIN 1000W Power, HAF 932 Full Tower, XP64
Octane V1 - 2.46 - CUDA 4.11 - OBJ's from Rhino4
Daniel79
all work fine but not UV mapping...
Good work!!
Thank's a lot
SORRY, MY ENGLISH IS BAD!
2 Xeon quad core E5440_8gb Ram_Nvidia GeForce 2GTX 780ti 3Gb/Nvidia Quadro K2000_Win10 64bit_Octane 3.02_Rhinoceros3D
SamPage
Daniel79 wrote:all work fine but not UV mapping...
I'm still investigating the UV issue. I can repeat it sometimes and not other times, so I am trying to nail down what is going on. I have a feeling though that the fix is going to have to wait on the improved *.obj exporter.
Sam
justix
Sam
Thanks, odd enough I had to try it using Rhino 5 Wip as it was crashing again in Rhino 4 and now it is not, can't find the 'Clear' option...
:D
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
SamPage
justix wrote: Thanks, odd enough I had to try it using Rhino 5 Wip as it was crashing again in Rhino 4 and now it is not, can't find the 'Clear' option...
If OctaneClearOptions is not coming up as a command, then the wrong version of the plug-in is loading. You can check by going to Rhino Options -> Plug-ins, select RenderOctane and click Properties. It should list the version as 1.022r01.01, and list three commands, OctaneClearOptions, OctaneOptions, and RenderOctane. It will also list the path of the plug-in that is loading, so if something other than the expected version is loading you can check in this location for errant older versions.
Let me know if you have issues,
Sam
justix
Sam
Thanks, Version loaded is 1.022r01.01 but only 2 options are showing LeftMouse > Render Octane and Right Mouse>Octane Options and in this last I only have the Octane Path and Samples.
AS we are on the matter I suggest a future option that could ease the pain of Manually renaming the exported obj for Future renderings.
As it is now everything is exported in a folder inside the same directory were the Rhino is opened, but like me I guess many users will have a single folder for most of their models,
in this way the Exported Obj will remain the same name overwriting anytime of an export.
I guess it would be awesome to actually Name the exported Obj in order to avoid OctaneExport.obj to be replace by mistake, in case someone (it happened to me) does export a new scene and forget to copy or rename the old obj for future renderings (the Ocs file does call for it).
Cheers
SamPage
justix wrote:Thanks, Version loaded is 1.022r01.01 but only 2 options are showing LeftMouse > Render Octane and Right Mouse>Octane Options and in this last I only have the Octane Path and Samples.
As it isn't a "everyday" command and rather just fix a previous mistake kind of thing, it isn't exposed on the toolbar, you have to type in OctaneClearOptions.
justix wrote:AS we are on the matter I suggest a future option that could ease the pain of Manually renaming the exported obj for Future renderings.
It is coming.
justix
It is coming.
Great! Thank Yo ;) u
justix
Actually, I've just noticed that I can't see the mtl file anymore exported...??
Return to “Rhinoceros 3D”
