Lamp with bulb (emitter) and a mirror to help see addition perspective.
The inside of the lamp shade is not lit, for both path tracing and direct lighting renders.
Resolution: 1024x768 at 2000 samples, for both renders.
Pre23 v4 - not understanding lamp shade test
- watchyour6
- MaTtY631990
Are you trying to achieve the look of a proper lamp shade.
- watchyour6
Yes. Simple enough, but I must be doing something wrong.
I've attached the ocs file.
Win 7 x64 | 2x GTX460 2GB + GeForce 8600 GT 256MB | Quad 2.93GHz | 8GB
- MaTtY631990
Heres a workflow, In the graph editor make a diffuse material and connect to your lamp shade and then make a RGB spectrum texture and connect to the transmission controller on diffuse material and set to pure white. You can only see the real effect in pathtracing.
- watchyour6
Thanks for the workflow tip. I'm still not getting a different result. Could you post an example illustrating the node setup and also the result rendered via pathtracing?
- MaTtY631990
So the output is from RGB spectrum is connected to input on transmission controller, and the diffuse material is connected to your model replacing the lamp shade material that was their, and leave the colour set to default and change transmission colour to white. Set your rendering kernal to pathtracing and this is result you should end up with.
- watchyour6
- p3taoctane
Thanks for the tip.
But how did you create that RGB spectrum node?
I do a right click Add and can't find that anywhere
Peter
Peter
- p3taoctane
Perfecto... thanks... there are hidden gems I have yet to find
Peter
Peter
