v3.08 and v4 cached particle rendering
crackfox
i opened a scene from 3.08 in v4 and apparently the cached alembic xparticles are not animating.
they only render in the state of the first frame.
- the xparticles have a octane object tag.
- check geometry is set to enable and all movable.
is there some problem with the v4 or am i missing something?
I don't know any problems.
crackfox
ok thanks aoktar. so i just need to set the octane object tag to the particles? thats it, it should work?
You may find the information here: http://www.aoktar.com/octane/index.html
crackfox
thanks,
i have this manual open all the time. the geometry is baked and cached as alembic with the objecttag set to force updates enabled.
still not moving in when rendering the sequence, stays the same as in the first frame.
i will report back again.
crackfox
and now they are rendering properly.
i swear, sometimes they do, sometimes not. if i start rendering at frame 800, then no updating. if i go from beginning, than its ok.
I'll take a look if you send me a scene.
