Particle age map doesn't work?
senorpablo
Trying to use particle flow to create some simple smoke. Max relies on the particle age map in a materials opacity to fade particles over time.
The particle age map doesn't seem to be compatible with Octane. I tried the baking texture and didn't have any luck.
Is there any workaround to get this working? I can't imagine how else to do any kind of fading particle without this kind of functionality.
paride4331
Hi paulforgy,
have you tried that?
senorpablo
That doesn't work. I've tried baking texture too.
paride4331
Hi paulforgy,
could you share (in Pm if you want) a scene with your issue please?
senorpablo
paride4331 wrote:Hi paulforgy,
PM sent.
pixelcan
Was this ever solved?
I'm having exactly the same problem.
Need to fade particles over time(age).
Any ideas?
senorpablo
Any news on particle age map?
Now that there is vertex color support, this seems like it might be closer to being possible.
paride4331
Hi senorpablo,
developers are working on it.
Return to “Autodesk 3Ds Max”
