it seems it is impossible to input an existing material. Is this correct? And can this be used as a layer material like in v-ray? As it is now it looks like it's the same as the mix material with more inputs instead of 2.aoktar wrote: Why do you need document? Everythings is same as in Octane materials.
What would be great is to have a stacking system instead of blending. IE, if Mat1 is a clear glass spec material and Mat2 a diffuse green, I would have a combined glossy green with both materials stacked on top of eachother and100% visible instead of a mix between values.
