light sphere material transfer
gsfcreator
I have an object that acts as a magical ball/sphere. it got all kinds of textures/materials. generally, it's a sphere with a special textures. Octane doesn't import it correctly.
here it is in firefly:
this is how octane imports:
after some tweaks (color change/opacity) that's what I could get. it won't show the "magical" texture:
poser material nodes:
I'm trying to figure out why this is happening with some materials, while others (most of them, actually) transfer without any problem.
thanks for your help.
Core I7-8700K, 32RAM, GTX1080Ti, win10
I think you might need a Diffuse material with an Emission.
gsfcreator
face_off wrote:I think you might need a Diffuse material with an Emission.
the thing is, I can't animate the lights (Emitters) in octane (or can i?). when I want to do a simple thing, such as creating a flickering light sphere, I keyframe the sphere/the light attached to it in poser. is there any way do achieve this in octane?
also, how do I control the fall-off of the light?
You should be able to use dial-linking to do this. Connect the emitter power to a dial and keyframe that dial.
https://docs.otoy.com/PoserH/PoserPlugi ... inking.htm
gsfcreator
face_off wrote:You should be able to use dial-linking to do this. Connect the emitter power to a dial and keyframe that dial.
thanks, Paul! so much to learn.
Return to “Poser”
