Hello,
I'm struggling to get a separate, isolated shadow pass out of OctaneBlender 3.05.3 (and SE, for that matter)
Could someone tell me if it's possible and, if so, how one would go about this? ...Or point me in the direction of a tutorial (There's lots of C4D tuts on the subject but nothing Blender that I can find).
Thanks in advance.
						Shadow Pass
- Whispermode
OK, managed it in SE using Object Layer Nodes in order to create Render Layer IDs... but I've no idea how this would translate to Blender.
Any help would be greatly appreciated.
- RajivMudgal
- Contact:
Hi
Check the attached blend file, Its a simple cube as object and plane as the shadow catcher as well as the reflection catcher.
Just render the file and check the viewer output in the node editor.
I use fusion but any compositor will do.
The attached images show both the shadow and Reflection as well as the Z-Depth Pass in actual use in an ongoing project,
I hope that helps.
I hope that helps.
Rajiv Mudgal
Film Maker and VFX Creative Director at DarkWhite Productions
Win 10 64 |3X Nvidia Titan | i7 5820k | 32GB
Hi RajivMudgal,
Thanks for the "blend" file.
By studying it I understand a very useful possibility for my work.
Learning how to get examples is very easy.
Thanks for sharing.
SimDal
Thanks for sharing.
 SimDal
Win 10 64, 4xGTX780ti 8xTeslaK80, Octane, Blender, Archicad
						- Whispermode
This works perfectly, Rajiv - thank you so much for taking the time.RajivMudgal wrote:Hi
I hope that helps.
[I've also updated to 11.24 from 11.21, as per your advice on DM, which solved the reflections problem]
So the basic shadow pass doesn't work in Blender? It seems to only give a white image. Shadowcatchers can't really be used in complex scenes...
Shadows pass renders nicely in the standalone, so I can always export orbx and render it there, but it would be nice to get this working in Blender too.
I have tried this Blend file, but I really don't get itRajivMudgal wrote:Hi
I hope that helps.
When I check the reflect viewer, i have the cube and it is black.
And I don't have reflection anywhere.
I was hoping that I would get the reflection from the cube.
(Blender 15.0 - 2.79)
How will this work exactly in a project - the shadow catcher is easy to use, but I need to create reflection
viewtopic.php?f=32&t=66352&p=334983#p334983
Win 10 - 64 bit, Intel Corei7-7800X CPU @ 3.50GHZ, 32 gb ram, 2x Gigabyte RTX 2060 SUPER 8GB, OctaneRender for Blender - The most recent stable build - Houdini indie 18.5.499
						LayerReflections pass is what you need. It's on the right under "Layer" passes section.
System – Windows 11
						System – Windows 11
I have tried everything(that I am able to)
I have also messed around with LayerReflections pass, but I don't know how to use it exactly.
An example/tutorial/Blend file - will be great to see how it works.
And furthermore Octane Blender is now changed, they removed (Blenders) Renderlayers in 15.1, so the above file from RajivMudgal is too old.
						Developers listed some python code you can use to make Blender Render Layers visible again - see below link:lakris wrote:And furthermore Octane Blender is now changed, they removed (Blenders) Renderlayers in 15.1, so the above file from RajivMudgal is too old.
viewtopic.php?f=114&t=65792#p334628
They said they would look into turning it back on in next release
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
