Version 3.08-RC3
Silverwing
MRoz wrote:Hi Ahmet,
Since Release 3.08-RC1.1 I experienced weird things with PMC mode.
All my materials becomes white, lighting works but materials aren't.
I thought it was because my materials were created in an older version but it seems that it's the same with new ones and fresh scene.
Release 3.08test6.1 is working fine for me though.
Thank you,
Maxime
I have to bump up that post vom MRoz since I have experienced the same behaviour.
Old scenes completely ignore Octane Materials when working in PMC mode. The materials just render as diffuse gray.
For me copy / pasting the scene into a fresh C4D File helped.
Maybe there can be done something about it.
Sorry, I don´t have a example scene right now but it should be reproducible with any scene that was created in Octane 3.07 and before.
Tried it with Octane 3.08 RC3 on C4D R19.053
Cheers,
Raphael
WIN 11 PRO 64 | ASUS X299 SAGE | 1X RTX 4090 3X RTX 3090 | i7 10980XE | 128GB RAM
frankjrmi
Kretschi wrote:Hello,
Thanks for the new build.
Works fine on Mac Cinema 4D R19...
One strange thing: Textures are rendered differently on front and back normals...
What is your Mac setup? I have a 2013 trashcan with AMD cards and still can't get Octane to run (I have to run it on my Windows machine).
Hi frankjrmi,
currently you still need an Nvidia GPU to work with Octane on your Mac,.
Please, have a look at this alternative eGPU solution via Thunderbolt port starting from this discussion on the Otoy forum:
viewtopic.php?f=30&t=62409
In this way, you can use the internal AMD GPU for system/monitor/OpenGL, while the external GPU is used only for CUDA rendering, at full power and with all VRAM.
At the following link you can find an extensive guide about eGPU solutions via Thunderbolt under Mac:
https://egpu.io/setup-guide-external-graphics-card-mac/
ciao Beppe
niestudio
Cheers,
Raphael
Irradiance mode is ticked by default when opening a 3.07 scene in PMC. When I untick it, the materials come back from grey.
When creating a new scene in 3.08 it's unticked by default
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
Kretschi
I have a 12 core MacPro (late 2010) with Nvidia Geforce 980 Ti and processor upgrade...
niestudio wrote: Irradiance mode is ticked by default when opening a 3.07 scene in PMC. When I untick it, the materials come back from grey.
Nice point. So it should be due wrong default value for the parameter. I'll fix if so. Thanks!
niestudio
typo in the camera tag custom LUT section
lucioing
Hi Ahmet!
So, 3.08 is here!
Maybe I'm wrong, but clicking on button (Image texture)
to load a map, I get this:
Instead, as always, this
The same, the others channel...
Thank you
L.
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
stefano-dear wrote:I have tried this release but is very slow on my Mac on C4D R19.053 - CUDA Driver Version: 387.178 - NVIDIA Web driver 378.05.05.25f06
I don't know the why... :roll:
And crash frequently:
_BugReport.txt
EDIT
The problem is caused by the "Camera Imager", when it is disabled everything works correctly!
Enabling from camera tag? Octane always have a camera imager effect as you did that or not. I'm not sure why it crashes but log points that a crash on the renderer.
stefano-dear
_BugReport.txt
EDIT
Camera Imager cause only slow movements on Live Viewer, crashes are caused by problems that I don't know...
Return to “Releases”
